jmcconomy Posted May 15, 2019 Report Posted May 15, 2019 Anybody in the NOVA area that would be down to program my radio for me. I'm getting quite feed up with it dumping the settings from chirp as soon as I go to test. Will even consider paying for it. Quote
marcspaz Posted May 16, 2019 Report Posted May 16, 2019 Do you have everything you need? Cable, latest version of CHIRP and laptop? If so, I may be able to meet you somewhere and can help you with your gear. jmcconomy 1 Quote
kidphc Posted May 16, 2019 Report Posted May 16, 2019 I have the gear also. What are you trying to program the NOAA stations? Quote
jmcconomy Posted May 19, 2019 Author Report Posted May 19, 2019 I have all the gear. Trying to program a couple local repeaters. Quote
kidphc Posted May 20, 2019 Report Posted May 20, 2019 You could just send the information to me. I can put the information into chirp and send back the saved file.Just keep in mind anything past memory slot 30 is receive only. Then you can at least have a file to look at how it was set. Also seems some locals are willing to come by. Then you can watch the process in person. It's pretty easy to do.Sent from my SAMSUNG-SM-G891A using Tapatalk Logan5 1 Quote
