BoxCar Posted November 26, 2019 Report Posted November 26, 2019 I'm looking at picking up an ICOM IC-F6011 for a transmitter either in my base or as the output for a repeater I can install. What I'm looking for are some thoughts on this units performance over time and if there are concerns over possibly reaching or exceeding the recommended duty cycle. They are reasonably priced both new and used on Flea-Bay. I know from past experience the brand is/was frequently cited by hams for its quality. Quote
WRAK968 Posted November 26, 2019 Report Posted November 26, 2019 I use Icom VHF radios at work all the time. Never had any issues with them and they are much older models. They outlasted the motorola radios by years.As for the F6011, It likely has the same duty cycle as other heavy duty mobile radios, that being about 20% on high power. Icom does not outright come out and say this, but the cooling fins look to be about the same size as those on the Kenwood 8180's. One important note is that the Kenwoods are 30W radios and the icom is a 45W, which could reduce the duty cycle, but knowing Icom I would say 20% is reasonable to expect. Thats my input at least so you may wish to wait till a diehard Icom user or tech comes in. berkinet 1 Quote
berkinet Posted November 26, 2019 Report Posted November 26, 2019 On 11/26/2019 at 4:17 PM, WRAK968 said: I use Icom VHF radios at work all the time. Never had any issues with them and they are much older models. They outlasted the motorola radios by years. As for the F6011, It likely has the same duty cycle as other heavy duty mobile radios, that being about 20% on high power. Icom does not outright come out and say this, but the cooling fins look to be about the same size as those on the Kenwood 8180's. One important note is that the Kenwoods are 30W radios and the icom is a 45W, which could reduce the duty cycle, but knowing Icom I would say 20% is reasonable to expect. Thats my input at least so you may wish to wait till a diehard Icom user or tech comes in. Not a comment on Icom per-se. But, regarding duty cycle. Depending on your needs and application a 20% duty cycle transmitter for a repeater may be marginal. Remember, the repeater duty cycle is the sum of all the inputs. I.e. two people each transmitting 20% of the time (12 seconds per minute), will put a 40% load (24 seconds per minute) on the repeater. n4gix 1 Quote
