Soladaddy Posted April 17, 2020 Report Posted April 17, 2020 I'm swimming around in the sea of mobiles, tossing to and fro between the CCRs, the new part 95ers and the old commercial stuff. I like the CCRs for the ease of PC programming but the performance I've witnessed isn't all that great. I have 20+ year old Kenwood TK-2100s that runs circles around the new btech MURS and that has me thinking about using older commercial gear but am not sure what are good models for GMRS, what to avoid, what's good for programming, what do the model numbers/letters mean? I'm leaning 880 for price, 256 channels and I think the ability to go into the 70cm band (I'm a ham) How does the 880 differ from a 880-1 V2.0? How does the 880 differ from a 863G? 8302U? I see a front speakerWhat does the G mean? I think a H suffix mean high power. Thanks Quote
axorlov Posted April 17, 2020 Report Posted April 17, 2020 TK-880 datasheet:https://criticalradio.com/Kenwood%20Spec%20Sheets/Data%20Sheets/TK780h_880h_ver2_k.pdf "H" means high power and bigger heat sink on the back, refer to the datasheet for the dimensions. There is some difference between v2.0 version and earlier (non-versioned, that is often called V1.0), but I can't weigh on that, since I do not own one. The "-1", "-2" and "-3" are not versions of the hardware, they are versions of alignment, refer to the datasheet. Soladaddy 1 Quote
WRAK968 Posted April 17, 2020 Report Posted April 17, 2020 For GMRS, Ver. 1 and Ver. 2 radios are the same. Ver. 2 radios have a slightly different schematic and some different features that are used in LMR/commercial operations. Soladaddy 1 Quote
n4gix Posted April 23, 2020 Report Posted April 23, 2020 Keep in mind that among the TK880 series, only the -1 has Part 95 certification. Soladaddy 1 Quote
Ken-642 Posted April 24, 2020 Report Posted April 24, 2020 I have a TK-880-1 v2 it is an awesome radio. The v2 has some fleetsync featured that the v1 does not have, but I have yet to have a use for them on GMRS. Just my 2 cents. Quote
Soladaddy Posted April 28, 2020 Author Report Posted April 28, 2020 Thanks. Still kicking this one around. Saw the 8180 can be programmed with Chirp and that got my attention. Quote
Jones Posted April 28, 2020 Report Posted April 28, 2020 Thanks. Still kicking this one around. Saw the 8180 can be programmed with Chirp and that got my attention. I have 2 TK-8180s, and a TK-7180 VHF unit, and they cannot be programmed with CHIRP. I'm not sure where you heard that. The only Kenwood radios that I own which can be programmed with CHIRP are the older TK-862 series 2, 4, and 8 channel units. Quote
Soladaddy Posted April 29, 2020 Author Report Posted April 29, 2020 This is the Kenwood section on Chirp's site: Kenwood TH-D7, TH-D7GTH-D72TH-F6TH-F7TH-G71TH-K2TK-260/270/272/278TK-260G/270G/272G/278GTK-360/370/372/378TK-360G/370G/372G/378G/388GTK-760/762/768TK-760G/762G/768GTK-860/862/868TK-860G/862G/868GTK-7102/8102/7108/8108TK-2180/3180/7180/8180TM-271TM-281TM-471TM-D700TM-D710, TM-D710GTM-G707TM-V7TM-V71TS-480HX/SATTS-590S/SGTS-850TS-2000https://chirp.danplanet.com/projects/chirp/wiki/Home Maybe they a newer additions? Quote
Jones Posted April 29, 2020 Report Posted April 29, 2020 Wow... I drastically need to update my copy of CHIRP. I guess I hadn't kept up in awhile. Quote
n4gix Posted May 5, 2020 Report Posted May 5, 2020 You must not have used Chirp in awhile! Every time you start it you'll get a reminder that a newer version is available... Quote
Lscott Posted May 5, 2020 Report Posted May 5, 2020 A bit off topic. I have a growing collection of hand-held radios, mostly Kenwood VHF and UHF commercial models, and the antennas are getting harder to identify as to band and frequency spilt. Most have no identification on them for the frequencies. The VHF antennas seem to be “fatter” than the UHF ones. However there are different frequency ranges in each band. Seems like Kenwood uses a color coded gasket around the connector to denote the frequency range. I found the site below that has a lot of the antenna models with the band spilt identified by color. http://www.cqcq.ca/viewtopic.php?f=13&t=86 Quote
Jones Posted May 6, 2020 Report Posted May 6, 2020 You must not have used Chirp in awhile! Every time you start it you'll get a reminder that a newer version is available... Nope. The computer I use CHIRP on is not connected to the network in any way, so it never checks for updates. That's how I got so far behind. To update or upgrade, I have to download files on a connected computer, then drop them onto a flash drive, and use the old "Sneaker Net" method to upload them to my radio programming laptop. "Sneaker Net" was developed in the day when you had to put a file onto a stack of punch cards, or a "floppy disk", then use your "sneakers" (powered by your feet) to run that file across the room, and install it onto another machine. See also: FFFTP - Fred Flintstone File Transfer Protocol. Quote
n4gix Posted May 7, 2020 Report Posted May 7, 2020 I'm familiar with the term, having cut my teeth back in the dark ages in IT (1960 to present). Quote
BoxCar Posted May 7, 2020 Report Posted May 7, 2020 I'm familiar with the term, having cut my teeth back in the dark ages in IT (1960 to present). Somebody else familiar with the the microphone test done on the first gen digital computers. Quote
