MaverickNH Posted May 2, 2020 Report Share Posted May 2, 2020 I only have a single repeater nearby that operates on 462.575 DPL 156 I've seen "complaints" about the Midland MXT400 saying it has limitations for use with repeaters. Some reviews say all 8 channels are all on or all off, or that it takes only a single code per channel. I'm not sure what they mean... Are repeater frequencies/codes "pre-set" or can one program them? With the MTX400 work with my in-range repeater? Thanks! WRFQ595/N4SRN Quote Link to comment Share on other sites More sharing options...
Riktar Posted May 2, 2020 Report Share Posted May 2, 2020 Some repeaters use a different tone for receive and transmit. Your MXT400 (as well as every other Midland GMRS radio) can only use the same code/tone on BOTH transmit and receieve. On the listing for the repeater do you see: 462.575 DPL156467.575 DPL156 Or do you see a different code/tone for each of the frequencies? Idf it is the same you can access that repeater. If they are different you are out of luck. At least with your Midland. Quote Link to comment Share on other sites More sharing options...
MaverickNH Posted May 2, 2020 Author Report Share Posted May 2, 2020 Yes, the listing is indeed: 462.575 DPL156467.575 DPL156 So it seems I'm in luck! When I "hit" a GMRS Repeater, do I get an audible signal like a HAM Radio repeater? Thanks, BRET WRFQ595/N4SRN Quote Link to comment Share on other sites More sharing options...
marcspaz Posted May 2, 2020 Report Share Posted May 2, 2020 The gen one MXT400 stinks. The gen two works fine...but no split tons support. Most repeaters have a tail...yes. Quote Link to comment Share on other sites More sharing options...
Radioguy7268 Posted May 3, 2020 Report Share Posted May 3, 2020 Many Ham repeaters will use a courtesy or "over" beep. Not all GMRS machines will use it, but some will. Some repeaters will not re-transmit "dead air" if you just kerchunk the machine without passing any audio. Quote Link to comment Share on other sites More sharing options...
MaverickNH Posted May 3, 2020 Author Report Share Posted May 3, 2020 I’m getting a “tail” so I think I’m in. Just nobody on yet If GMRS did FT8, it would be hot! Quote Link to comment Share on other sites More sharing options...
