fremont Posted July 22, 2020 Report Posted July 22, 2020 How much cable did I waste adjusting the two blades to cut at the proper depth? Too much to note. That was an hour I'll never get back. Quote
0 marcspaz Posted July 22, 2020 Report Posted July 22, 2020 That stinks... I have been making cables for 35 years. Always do them by hand with a straight razor. Make sure its sharp so you need minimal pressure and you will never cut the shield or center lead by mistake. The only time I use a tool is when I strip very thin cables that I can hold with needle nose pliers and wire strippers like the one in the picture. And I don't bother setting the guide stop. Again, just make sure they are sharp and use light pressure to squeeze and twist and you are good to go. Quote
fremont
1 answer to this question
