Kugellager Posted December 2, 2020 Report Posted December 2, 2020 Stumbled across this today. I wonder if it will be part 90 certified? http://www.anytone.net/pro_info8.html http://hamradio360.com/shop/anytone-at-888-uhf-400490mhz-mobile-radiotransceiver-amateur-radio/#productdetail Also comes in 2m, 1.25m and vhf versions. EDIT: I just realized this is oldish and is part 90 certified. https://apps.fcc.gov/oetcf/eas/reports/ViewExhibitReport.cfm?mode=Exhibits&RequestTimeout=500&calledFromFrame=N&application_id=HB5rHpESynjlwIEtYp7liQ%3D%3D&fcc_id=T4KAT888U John];’) Quote
rppricer Posted December 2, 2020 Report Posted December 2, 2020 what are you asking anytone are real good radio but if you are going to use this with GMRS you will need to up your licence to ham licence because of the wattage this radio put out. rppricer 1 Quote
SteveC7010 Posted December 2, 2020 Report Posted December 2, 2020 what are you asking anytone are real good radio but if you are going to use this with GMRS you will need to up your licence to ham licence because of the wattage this radio put out.This is absolutely incorrect! No amateur radio service license allows operations on GMRS frequencies. Power level is limited per FCC GMRS rules, not a ham license. gortex2 1 Quote
Kugellager Posted December 3, 2020 Author Report Posted December 3, 2020 I posted because I had never stumbled across this radio in my searches. Thought it was new but was wrong. Sorry. John];’) Quote
SUPERG900 Posted December 4, 2020 Report Posted December 4, 2020 There are a gajillion radios out there that are capable of operating on GMRS frequencies - but aren't certified by the FCC for GMRS operation. The reason for this is twofold. In the first case - someone has to apply for certification. That takes time and money. Secondly, in order to be successfully pass certification, the radio will need to be made incapable of operating outside of GMRS frequencies, and in compliance with GMRS power levels, which vary per channel (and per mobile/HT as well). If the radio design is amenable - only a firmware change will be needed. However, this isn't free or cheap either. Lastly, GMRS radios have a limited market - they're only good for use in the US. In order to amortize the work needed to get a radio certified - an asian manufacturer is going to need a local sponsor (i.e. US distributer) to make a commitment to a minimum purchase in order to make it worth their while. Radio equipment authorizations vary by countries. It's a fractured system. It's always been this way, unfortunately. berkinet 1 Quote
