FTM 3207DR 4CFM
                    CAN YOU USE 3200 PROGRAMMING TO WORK WITH 3207 /2M-70CM  IF YOU CANT IS IT BECAUSE IT HAS UHF PICK UP A USED ONE IM ONLY 70CM CHIRP HAS 3200 PROGRAM
5 answers to this question
No. that is not type approved for GMRS nor does it have transmit capabilities in the GMRS band.
IM GLAD I PUT THAT OUT THERE
   THANK YOU NOT A BIG INVESTMENT  IT WILL JUST BE A RECEIVER
Please dont type in caps, feels like I'm being yelled at by some random troll.
That is an expensive receiver. C4FM is ONLY used on the ham side for System Fusion radios, so you wont hear digital police or fire with it. Likewise, as was pointed out, GMRS will not be doable with the FT3207 as it only transmits 430-450. There is a mod you can do that will increase the TX range of the radio, however this can cause a fair bit of issues down the road.
That being said, it looks like the ADMS3200 software should program both the 3200 and 3207. Simply do a read from the radio so the software knows what radio it is looking at and start programming.
