Well first there are no "Ham Radios" that are also certified for GMRS in spit of what you may read on various web sites.
There are many Part 90 commercial radios, and some even include Part 95 certification, that are designed and tested for outdoors operation so are weather proof, rain - dust etc. Many of those radios can be programmed to operate over part or the full Ham 70cm band.
I have the following models from Kenwood. There are others from Motorola along with other major manufactures.
TK-370G
https://fccid.io/ALH29473110
https://mra-raycom.com/wp-content/uploads/simple-file-list/Specifications/portables/TK-270G-370G-Product-Brochure.pdf
TK-3170
https://fccid.io/ALH34713110
http://www.swscomm.com/kenwood/TK-2170_3170.pdf
TK-3140
https://fccid.io/ALH32263110
https://www.ameradio.com/doc/Kenwood_TK2140_3140.pdf
Be careful of the model type. Look at the specifications because the UHF radios come in several frequency ranges. For GMRS you want to cover at least the 460 MHz to 470 MHz range. A few models will cover 400 MHz to 470 MHz which is perfect for Ham and GMRS. I have successfully programmed the above models down to about 440 MHz which covers the repeater and most of the simplex section of the Ham 70cm band per the ARRL published band plans. The software will put up a warning window about the out of band frequency but will accept it anyway when you click OK.
https://www.icomamerica.com/en/amateur/amateurtools/US-Amateur-Band-Plan-10-2017.pdf
Well first there are no "Ham Radios" that are also certified for GMRS in spit of what you may read on various web sites....
I think you either mis-read the post, or were mentally responding to another topic.  @jeremyb66 was asking about waterproof ham radios.
Personally, I don't know of any. But, that doesn't mean they don't exist.
The OP wrote "...what would be a good waterproof gmrs/ham radio?"
So he was inquiring about both services.
Yaesu VX series are submersible. VX6 is currently available new, VX7 and VX8 are discontinued. These are ham, not GMRS radios. I have Yaesu FT1XD, it is not submersible, but fairly good weather-protected. Build quality is on par with commercial radios.
Hello Jeremy.
I cannot speaker to quality and have no experience with it, but I stumbled across this ham radio this morning. The importer asserts waterproof submerged 3 feet for 3 hours. See the following link: https://www.ruggedradios.com/index.php?main_page=product_info&products_id=2262
Michael
WRHS965
KE8PLM
If you're really interested in this radio I would research it a lot more. Rugged Radios has been known to take cheaper Chinese radios, rebranded the radio and sold them at inflated prices.
Somebody here will likely recognize the original manufacture, if the radio was rebranded, and where you could buy one much cheaper.
Took a quick look, this tyt looks quite similar https://www.amazon.com/gp/product/B07CY6CRZH/
My suggestion, that I used extensively with expensive hand held radios, is buy a hand microphone.  I kept the radio inside my jacket looped the mic out.  Microphones cheaper than any radio.  This was the fire service before all these fancy new equipment.
