GMRSHAM Posted January 29, 2021 Report Share Posted January 29, 2021 Don't see that option in the KG-805g softwareTo access the repeater states: OPEN 462.625 445 DPL The SW has DN445 and DI445 under QT/DQT not sure which way to go with this to access the repeater Thanks for the help in advance Quote Link to comment Share on other sites More sharing options...
wayoverthere Posted January 29, 2021 Report Share Posted January 29, 2021 Don't see that option in the KG-805g softwareTo access the repeater states: OPEN 462.625 445 DPL The SW has DN445 and DI445 under QT/DQT not sure which way to go with this to access the repeater Thanks for the help in advance (Edited the qt/dqt part as I was left field wrong on the meaning; see n1das post below. Left the second part because it largely stands, minus minor corrections to the menu items) Since you can change it from the radio menu (it'll be "T-DCS" in the menu), i'd set it for D445N first (normal); if that doesn't work, use the menu to change it to D445I (inverted). Quote Link to comment Share on other sites More sharing options...
GMRSHAM Posted January 29, 2021 Author Report Share Posted January 29, 2021 Thank You wayoverthere - I will give that a try Quote Link to comment Share on other sites More sharing options...
MacJack Posted January 29, 2021 Report Share Posted January 29, 2021 I agree with wayoverthere suggestion... BUT if that does not work what I learned from my 805G is best to go back to factory settings then add just the channels and not the PL codes but do them via the HT menu for the DCS. Hope that helps from me having same issue... Just a work around.Jack Edit: Then upload radio settings to software files. wayoverthere and GMRSHAM 2 Quote Link to comment Share on other sites More sharing options...
wayoverthere Posted January 29, 2021 Report Share Posted January 29, 2021 I agree with wayoverthere suggestion... BUT if that does not work what I learned from my 805G is best to go back to factory settings then add just the channels and not the PL codes but do them via the HT menu for the DCS. Hope that helps from me having same issue... Just a work around.Jack Edit: Then upload radio settings to software files.if it's something you're going to use regularly, definitely worth adding to its own memory slot once you get it figured out. my setup is the base 30 presets, my 3 local repeaters (2 of them on .625 with different tones), and then a second set of repeater channels (as "new 15r" through "new 22r") to have an extra set when traveling. GMRSHAM and MacJack 2 Quote Link to comment Share on other sites More sharing options...
n1das Posted January 29, 2021 Report Share Posted January 29, 2021 QT is dealing with sending a tone on transmit, DQT is listening for a tone on receive. it'll be the transmit tone that's your "key" to accessing the repeater, so focus there. Since you can change it from the radio menu (it'll be "T-DCS" in the menu), i'd set it for DN445 first (normal); if that doesn't work, use the menu to change it to DI445 (inverted). Uhhh...NO. QT is Kenwood's Quiet Tone, aka CTCSS/PL. (analog tone)DQT is Kenwood's Digital Quiet Tone, aka DCS/DPL. (digital code) DN445 is what you need to encode on transmit. DCS 445 normal is often listed as D445N. T-DCS DN445 should work. The N (normal) and I (inverted) refer to the polarity of the DCS waveform. This is my favorite technical reference for DCS:http://onfreq.com/syntorx/dcs.html Other DCS information:http://www.repeater-builder.com/tech-info/ctcss/ctcss-overview.htmlhttps://mmi-comm.tripod.com/dcs.html For the current ETSI Standard TS 103 236 Continuous Tone Controlled Signalling System (CTCSS) and Digitally Coded Squelch Signalling (DCSS) document, check out the ETSI Standards search page and search for ETSI TS 103 236. Quote Link to comment Share on other sites More sharing options...
wayoverthere Posted January 29, 2021 Report Share Posted January 29, 2021 Uhhh...NO. QT is Kenwood's Quiet Tone, aka CTCSS/PL. (analog tone)DQT is Kenwood's Digital Quiet Tone, aka DCS/DPL. (digital code) DN445 is what you need to encode on transmit. DCS 445 normal is often listed as D445N. T-DCS DN445 should work. The N (normal) and I (inverted) refer to the polarity of the DCS waveform. This is my favorite technical reference for DCS:http://onfreq.com/syntorx/dcs.html Other DCS information:http://www.repeater-builder.com/tech-info/ctcss/ctcss-overview.htmlhttps://mmi-comm.tripod.com/dcs.html For the current ETSI Standard TS 103 236 Continuous Tone Controlled Signalling System (CTCSS) and Digitally Coded Squelch Signalling (DCSS) document, check out the ETSI Standards search page and search for ETSI TS 103 236.Thanks for setting me straight.guess I had that a bit off in my head Quote Link to comment Share on other sites More sharing options...
