I have a subject requesting access to a repeater. One thing I do is varify the call before sending out the access codes. Today the FCC ULS doesn't seem to be working for me and I cant figure out why. It refuses to look up names, calls, or FRN. At first I thought the user made up the call, however upon seeing proof that the call is real I tried again with my call on the ULS and it says the call does not exist. Is anyone else having this issue?
It is finding my call signs, but it won't pull up the data when you click on it. I wonder if it's under maintenance.
I just saw an active alert for the system: "The FCC is currently experiencing an issue with downloading authorizations using Google Chrome........ use Firefox at this time"
yep Im using firefox and it just returns "The term doesnt exist" Little odd but I guess theres maintenance issues so at least I know its not me.
  On 2/10/2021 at 12:16 AM, WRAK968 said:
Still not working for me. This is what I get when doing a search, Does this for both lower-case and upper-case
I searched for your call sign using main search page and received the same results as you. Then I performed the search from the advanced search page and had success. See below.
Michael
WRHS965
KE8PLM
Reply to this topic...
