CHIRP doesn't recognize my Btech V1
jk06
11 answers to this question
I did that but still no luck, My MacBook OS is the most current version. Chirp still isn’t recognizing the device.
It is possible that it may be the issue with your USB cable.  What USB cable did you buy and where? Did your MacBook OS recognize the cable and install driver?
I bought my first USB cable to use with CHIRP from Amazon. When I plugged it in Windows 10 didn't recognize the cable and didn't install the driver. I had to hunt Internet for the driver.
The second USB cable I bought was BTECH PC-03 FTDI Genuine USB Programming Cable from this MyGRMS site. Windows 10 recognized that cable and installed driver automatically
Link to comment
Share on other sites
That’s the same, cable that I have. The MacBook allows the driver install and the chirp install. I’m stuck at the point where the chirp install options where the gmrs device isn’t recognized.
Is there a cheet sheet for this install in a Apple product? Any other recommendations?
Link to comment
Does your CHIRP on your MacBook see virtual COM port?
Check this page for different Mac OS drivers:  https://ftdichip.com/drivers/vcp-drivers/
Link to comment
I had a similar issue - and the cable I had had an issue up near where it connected to the radio. While it worked fine on a different baofeng radio - the housing caught just a bit on the lip of the recessed area where it plugged into the radio - and it did not allow the two plugs to quite seat all the way.
I shaved a tiny bit of plastic off the cable plug (not the radio), and once it seated properly it was ok.
I have no idea if this is your situation, but it sounds very similar.
Hope it helps.
Jim
Link to comment
Hope it helps.
Jim
I had this problem with the Btech PC03 programming cable when I used it with my Retevis RB26 GMRS.  We live in 2-story home and my two children live upstairs.  My wife or I had to yell pretty loud for them to hear us sometimes, so I purchase a 5-unit Retevis RB26 package from Amazon to use as an intercom system. They work great!  Three radios are in the bedrooms with other two in her kitchen and my office.  I used Chirp to program the key lock function on the PF1 key.  It came programmed for monitoring.  My kids would sometimes hit the PF1 or 2 keys instead of the PTT key and change the channel.  The only bad thing is it will return to unlocked if powered off, but I just have to press the PF1 for a couple of seconds to lock the keys again.
Link to comment
