Btech GMRS V1 initial programming
Hi,
 I just purchased my Btech GMRS V1 and wanted to know if I need to program in the frequencies or any other codes before using? My purpose of this is really just to see the benefits of using this type of technology.
I live in western washington and was trying to reach out to anyone using GMRS but have not had any luck.
4 answers to this question
Hi,
For simplex or repeater use, programming should not be nee the only setting you may need (especially on a repeater) is ctcss/DC's tones, which can be set from the front panel, no computer needed.
In many places, gmrs is used (as is its primary intent) within families/groups, so generally stick to their group. also, traffic is pretty low I some areas, so there may be no one there, or they may be running tones (which act as a filter) and not hear you.
thanks for the feedback. so do you know of a step by step guidance for CTCSS/DC TONES? again, I'm new and willing to learn but not sure if the manual really helps me.
thanks,
John
thanks,
John
I don't know of a good step by step offhand, this thread translates some of it:https://forums.mygmrs.com/topic/1978-translating-repeater-info-into-chirp-btech-gmrs-v1-vocab/
That said, it's really just knowing what codes the repeater uses, the menus are fairly straightforward for that part. Once you hit the menu button, scroll through and look for t-ctcs or t-dcs, depending what tones the repeater uses (if there's decimals, it's ctcss, 3 digit number, possibly followed by I or N is DCs). Hit menu to select that item, then scroll through to the correct tone, and hit menu to confirm (this is your "input tone").
You can also set a receive tone as well, but since it functions like a filter, you're fine leaving it off unless you only want to hear the repeater traffic on that channel.
