OK, I'm feeling like an idiot...  I'm sitting here holding a 3/4" NMO mounting bracket in one hand and the Midland MXTA24 cable+mount in the other and cannot see how these two work together.
If I unscrew the base plate (the 1-1/8" threaded ring with o-ring) from the Midland cable, what I'm left with is a 3/8" stem with a plastic collar sitting on it which is 0.614" diameter (about 1/8" too small).  It slops around in the 3/4" mounting hole and the whole assembly won't screw down tightly.
Should I just go with a 3/8" mounting hole and fab up my own bracket?  Or am I missing something really obvious....?
  On 3/30/2021 at 8:01 PM, WRAF233 said:
YouTube search 3/8 NMO Mount
The NMO I use are 3/8" - 3/4" range. I always do 3/8" hole.
Did lots of searching and honestly found nothing useful.... (mostly all just about drilling a 3/4" hole in the roof, which is not my application)
I guess even though the Midland product description says "works with both 3/4" and 3/8" I guess it doesn't actually work with 3/4" mounting holes....
I tried to post the YouTube video but wouldn't come through here.  It's in there with 3/8" hole in an F150 I think.  Search 3/8 NMO Install by SevenFortyOne.
  • 2 weeks later...
Reply to this topic...
