JoetheBugMan Posted July 29, 2021 Report Posted July 29, 2021 Any recommendations on what antenna to use with a repeater? Thank you in advance. Quote
0 BoxCar Posted July 29, 2021 Report Posted July 29, 2021 Repeaters require "high site" locations. High site means mountain top, highest building or tallest tower in the area. On mountain tops, lower gain antennas work better as they are more omnidirectional. As the gain goes up, the antenna pattern starts to resemble a donut more than a slightly squished ball. This increases the radiation pattern more to the horizon rather than filling gaps nearer the antenna. That said, an omni rather than a beam type antenna is what you are looking for. There are several designs that meet this requirement from vertical whip types to vertical poles with multiple folded dipole antennas attached. Your wallet will be a big deciding factor on which antenna you install. rnavarro, kipandlee, JoetheBugMan and 1 other 4 Quote
0 Lscott Posted July 29, 2021 Report Posted July 29, 2021 1 hour ago, JoetheBugMan said: Any recommendations on what antenna to use with a repeater? Thank you in advance. I have a buddy that wants to put up a Ham 70cm repeater, about the same as a GMRS one but a bit lower in frequency, when the site is ready. He spent over $300 on a USED multi-bay folded dipole antenna for it. JoetheBugMan 1 Quote
0 gortex2 Posted July 30, 2021 Report Posted July 30, 2021 DB408 is my go to antenna for a tower site. I do run some DB404 but the 408 has a bit more gain. In NY winters they have lasted for years. kipandlee and JoetheBugMan 1 1 Quote
0 JoetheBugMan Posted August 2, 2021 Author Report Posted August 2, 2021 On 7/30/2021 at 6:42 AM, kb2ztx said: DB408 is my go to antenna for a tower site. I do run some DB404 but the 408 has a bit more gain. In NY winters they have lasted for years. Thank you. That was one of the 3 on my list. Quote
0 daschnoz Posted August 3, 2021 Report Posted August 3, 2021 I'm assuming that you are looking for somthing to put on a tower. If you have the room for a 17-foot antenna, I suggest a Tram 1481. I have one on my garage and I can hit a 2m HAM repeater that is 70 miles away. When the conditions are JUST RIGHT, I can hit a GMRS repeater that is 40 miles away with a good bit of obstructing terrain in the middle. 8.3dbd of gain on VHF, 11.7dbd of gain on UHF. NOTE: That's dbd, not dbi like just about everyone else specs their antennas. From dbi, subtract 2.1 to get to dbd. So an antenna that boasts 2.1dbi = 0dbd, which is unity gain. I have mine tuned so that my HAM bands are close to 1:1 in the middle of each band. GMRS is up around 1.7:1, which is not great, but still usable. At 2:1 SWR, about 10% of the power is being sent back to the radio, so my 50W is really somewhere between 40-45W (coax losses not withstanding). The ground plane is adjustable and there is a good bit of adjustment remaining in the proper direction, so I'm sure that I could get the SWR lower in the GMRS band if I tried. If you do get one, get it from Staples. Yes, the office supply store. They have the best price around. Finally, don't go cheap on the coax. JoetheBugMan 1 Quote
0 Dilettante Posted September 22, 2022 Report Posted September 22, 2022 So if that is #3 - what are the #1 and #2 choices??? Quote
0 JB007Rules Posted September 22, 2022 Report Posted September 22, 2022 I have a DB408-b on my Rugged 575 machine and a DB420 on my Crete 600 machine and they are absolute screamers!! In my neck of the woods (Northern IL), we typically all use folded dipoles and we find they run smoke around fiberglass sticks! Just my 2 cents Ohh and my base antenna on my house is also a DB408 but it's only up 50'. But even at only 50' it talks like no mans business. Quote
0 W3NPA Posted September 23, 2022 Report Posted September 23, 2022 I use the Comet CA-712EFC. It's been a great antenna so far... kerstuff and AD4GC 2 Quote
0 WRKC935 Posted September 23, 2022 Report Posted September 23, 2022 Dude, it really depends on your situation and install. Everyone is gonna tell you a 408 or a 420, and those are damn fine antenna's in certain situations, but NOT in others. So I am gonna ask a couple questions before I answer. First is what height is it gonna be mounted at? Second is what sort of tower is it gonna be mounted on? Third is what coverage footprint are you looking at/ And finally what repeater and duplexer are you gonna be running? Look forward to your answers and helping you out more. Quote
JoetheBugMan
9 answers to this question
