jgillaspy Posted August 18, 2021 Report Posted August 18, 2021 Hey All, IO bought a Wouxun KG-UP920P-A knowing it had a failed final MOSFET thinking I could do the repair. I had no idea the piece sas so small. I just don't have the tools/skills for this repair. I'm having poor luck finding anything local to San Antonio, TX for repair. Anyone have some place/someone to whom I could shit it for repair? I'm only into it for $75 so far, so unless it is an expensive fix (already have 4 x MOSFETs) I'll still come out ahead. Here is a link to the repair process I found online - https://owenduffy.net/equipment/KG-UV920P/index.htm Thanks, JG Quote
BoxCar Posted August 18, 2021 Report Posted August 18, 2021 If you have the circuit board with the failed parts out of the case, take it and the parts to ay radio shop and ask them for a quote to replace the components. They may do the work for only the bench rate as there would be no disassembly or testing involved. Quote
jgillaspy Posted August 19, 2021 Author Report Posted August 19, 2021 T0 remove the board from the chassis I have to remove the antenna connector, but it isn't small. What a design. . . JG Quote
gman1971 Posted September 13, 2021 Report Posted September 13, 2021 This is how you repair a CCR... DeoVindice and mbrun 2 Quote
