Zello Gateway that does COR
WQUX891
Does anyone have experience with the Solidtronic ST-RoIP4?  We are currently using the RoIP1, but it is VOX and has a tendency to clip conversations when someone pauses.  The RoIP4 says it uses COR; but, is that only for Zello Work, or does it do COR with the free Zello account?
http://www.solidtronic.com/cms/?PRODUCTS___ST-RoIP4_Series_RoIP_Gateway
Secondarily, does anyone know of any other COR Zello interface that you don't need Zello Work to use?  The RoIP4 is quite expensive!
Thank you,
5 answers to this question
If you have a spare PC you can use Zello in gateway mode and have it handle COR/PTT signalling via the com port - this is cheaper than the Solidtronic approach but arguably also a bulkier piece of equipment: https://support.zello.com/hc/en-us/articles/230749207-Enabling-radio-gateway-mode-in-Zello-for-Windows-free-app
You just need to add some +5V pull up resistors to the com port signaling and it'll work just fine.
You might want to get a hold of Cory or Buddy with the Midwest GMRS group - I know they're using the SolidTronic for their Zello gateway.
Edited by JeepCrawler98
Thank you!  I have been able to modify the Windows program to get into gateway mode.  Would you happen to have a schematic of what you did?
Also, would you know what these mean, since there is no help menu:
-In TX Signal: RTS or DTR
-In RX Signal: CTS, DSR, Ring, CD
I am assuming the following, but this is my best guess:
RTS = Radio Transmit Signal (PTT?)
DTR = ???  Something Transmit Relay???
CTS = Continuous Tone Squelch
DSR = Digital Squelch Receive?  (DCS?)
Ring = ???
CD = ???
We are using DCS, so I am assuming my settings would be DTR and DSR; but, I have no idea.
Thank you for your help!
Search up some stuff on the RS-232 data standard, and I think it will help you.
CD = Carrier Detect
RTS = Request to Send
CTS = Clear to Send
DTR = Data Terminal Ready?
DSR = Data Set Ready?
Ring = ??? Detect ringing voltage on the line?
It's been too many years since I messed around with doing Modem stuff over radio channels. At one time it seemed like the future for SCADA control. That was a LONGGGG time ago.
