Reido Posted September 21, 2021 Report Share Posted September 21, 2021 Hey everybody. I am new to this and want to set up a repeater. I've read in other posts that you don't need any additional paper work outside of your GMRS License to set up a repeater. My question is, can I set up a repeater on somebody else's property with my license if I have permission to do so from the property owner and there was no way for the repeater site to transmit directly from that location? (i.e. no hand mic capability at that location) The "direct control' language is kind of confusing in the part 95 section of the FCC language. Quote Link to comment Share on other sites More sharing options...
OffRoaderX Posted September 21, 2021 Report Share Posted September 21, 2021 Yes. Quote Link to comment Share on other sites More sharing options...
mbrun Posted September 21, 2021 Report Share Posted September 21, 2021 Seconding the OffRoader’s “Yes”. BTW, a repeater is considered to be under automatic control.MichaelWRHS965KE8PLM Quote Link to comment Share on other sites More sharing options...
tweiss3 Posted September 21, 2021 Report Share Posted September 21, 2021 You do need to maintain some form of control. Typically this is done with DTMF tones so you can shut down the transmitter, and you do need to be able to get to the site to maintain the equipment reasonably. JLeikhim 1 Quote Link to comment Share on other sites More sharing options...
JLeikhim Posted September 22, 2021 Report Share Posted September 22, 2021 You do need to maintain some form of control. Typically this is done with DTMF tones so you can shut down the transmitter, and you do need to be able to get to the site to maintain the equipment reasonably.Yeah if the repeater starts interfering with Public Safety after hours or on a weekend you definately need to be able to shut it down. If the FCC calls you and it is stuck on, do you have access to the repeater? Sent from my SM-T350 using Tapatalk Quote Link to comment Share on other sites More sharing options...
OffRoaderX Posted September 22, 2021 Report Share Posted September 22, 2021 1 hour ago, JLeikhim said: Yeah if the repeater starts interfering with Public Safety after hours or on a weekend... And how, exactly, would that ever happen? Quote Link to comment Share on other sites More sharing options...
JLeikhim Posted September 22, 2021 Report Share Posted September 22, 2021 And how, exactly, would that ever happen?I used to chase down such interference for Motorola and it happened many times. Bad power amps, bad isolator panels. Once a 220 MHz ham repeater plus FM broadcaster mix. Sometimes lightning damages stations and they go bananas. . Sent from my SM-T350 using Tapatalk Quote Link to comment Share on other sites More sharing options...
OffRoaderX Posted September 22, 2021 Report Share Posted September 22, 2021 21 hours ago, JLeikhim said: I used to chase down such interference for Motorola and it happened many times. Bad power amps, bad isolator panels. Once a 220 MHz ham repeater plus FM broadcaster mix. Sometimes lightning damages stations and they go bananas. . To the OP: It is purely my opinion, but, on your list of worries when running a GMRS repeater, this should be at the bottom of your list. I run a GMRS repeater that has about 900 square miles of coverage, and this is not even on my list of concerns. Pigs flying into my antenna is higher on my list.. Sshannon and WRHS218 2 Quote Link to comment Share on other sites More sharing options...
MichaelLAX Posted September 22, 2021 Report Share Posted September 22, 2021 1 hour ago, OffRoaderX said: Pigs flying into my antenna is higher on my list.. Have you given Wayne and Garth Zello access from Aurora Illinois?!? Scha-wing!!! Quote Link to comment Share on other sites More sharing options...
