Posted (edited)
There’s a link in the listing to sign up with the SWCRS; once someone in the admin team reviews your application you’re sent a link with a password that will give you the info to all machines on the network, including the Lemmon 650.
We centrally manage access to all machines as opposed to on a per repeater basis, otherwise we’re constantly inundated with requests for each one considering there’s a good number of them we look after.
Edited by JeepCrawler98
@JeepCrawler98 I’m a casual GMRS user and the Lemmon 650 has been my go to repeater. Unfortunately, I have a midland mxt 115 which does not support the most recent change to the tone scheme for the repeater. What was the reason for the change and will this be the same in the future for the Lemmon 650? Thanks in advance
Posted (edited)
@WRFS422 We had some persistent issues with less than savory folks getting in there and causing trouble; the PL on Lemmon has been changed in the past because of this but with non-split tones of course it’s not difficult to force your way back in.
The tone scheme implemented now is permanent; we always try to make it as easy as possible to get on the machines so long as it stays clean - unfortunately we had to implement the scheme we have now to keep the riffraff off.
@JeepCrawler98 I suspected that was why the system was switched to split tones. I completely understand and appreciate the steps you've taken to keep the system free of interference and riffraff. I'm still able to hit the Tucson 550 to get into the linked system, although there is some static. I'm also still able to use the stand alone repeater on Mt. Lemmon to talk to local folks. Maybe, I'll look at getting a radio that is capable of split tones in the near future without spending a ton of dough even though that's the nature of this hobby. Thanks for the info.
Radioddity DB20-G: $109, cigarette lighter plug, 20 watts, programmable channels and split tones.
Clone Anytone AT-779UV shown - $99
