headlayoutman1 Posted February 8, 2022 Report Posted February 8, 2022 Wondering if anyone has tried this base station antenna on their GMRS setup ? , lots of gain for the price , would like some feedback on its performance . here is a link to take a look . https://buyantenna.com/index.php?route=product/product&product_id=655 Quote
gortex2 Posted February 8, 2022 Report Posted February 8, 2022 Appears same as the TRAM 1481 and most likely made by the same china company. Most of the multi piece trams fall apart after a few years. Basically a hoppy antenna. Mine last 2 months in NY before it snapped in the wind. Since them I only use commercial LMR antennas made by reputable companies. gman1971 and WROZ250 2 Quote
gman1971 Posted February 9, 2022 Report Posted February 9, 2022 8 hours ago, gortex2 said: Appears same as the TRAM 1481 and most likely made by the same china company. Most of the multi piece trams fall apart after a few years. Basically a hoppy antenna. Mine last 2 months in NY before it snapped in the wind. Since them I only use commercial LMR antennas made by reputable companies. Few years is more like few months. They develop water ingestion and the foam inside soaks water so things corrode real fast. Verticals tend to shoot out with a vertical takeoff angle, so it will reach very far, but up on the clouds... instead of a gigantic (and usually ineffective) antenna, I would get this for UHF: https://www.ebay.com/itm/133927735178?epid=1941709490&hash=item1f2eb70f8a:g:yowAAOSwIytgUyhQ G. WROZ250 and gortex2 2 Quote
WROZ250 Posted February 9, 2022 Report Posted February 9, 2022 11 hours ago, gman1971 said: I would get this for UHF: https://www.ebay.com/itm/133927735178?epid=1941709490&hash=item1f2eb70f8a:g:yowAAOSwIytgUyhQ G. Could not agree more! Say what you want about dipole arrays being 'old school', but the reality is they work, and work well. Very low angle of radiation (<10 degrees in most cases), last for years in the crappiest conditions and, none of the issues found in the cheap multi-section verticals, all of which as noted, eventually suffer from 'water ingestion'. gman1971 1 Quote
