Kg-1000g faceplate install overhead Jeep Wrangler
Hello
has anyone successfully installed just the faceplate of the Wouxun 1000g overhead in a Jeep Wrangler, with the main body installed elsewhere ?
I haven’t been able to find a mount that will support just the faceplate. Seems as if every mount wants to install the entire radio overhead.
5 answers to this question
i did mine this way. the radio head is mounted to the plastic with what i call plumbers strap or tape, then i used a few small bolts and drilled thru the plastic to mount the head. the radio is attached to the factory amp in the knee area. if u put it here u have to divert the floor heater vent so it doesn't blow on the radio, here its get s below zero so i just dont use floor heat unless i'm just warming up the jeep. I'm going to make a mic cable and run it down to the middle of the am/fm radio area somewhere so i dont have the mic cable like it is. can't decide if i want to-do the pass or driver side and i think i'm just going to try to find a cat5e wall mount end or something to make it look good
20210926_143518.thumb.jpg.0a67f99863a2752d2db9ab6b2a55c83c.jpg20210926_143521.thumb.jpg.594d3685798326b54f5eaf0c91c3d63c.jpg20210926_162139.thumb.jpg.9fc8f5f78f0e68e7a6fedcb7ef1cd7f5.jpg
Many thanks !
Do you think the radio faceplate would stay with the use of some locktight (commercial Velcro?) or a suction cup? Wondering if I need to really screw through the plastic ??‍♂️
what bracket did you use for the radio head/ faceplate ?
i wouldnt trust that to hold the head from falling off the way we bounce around some times, plus when it get super cold here they tend to fall off the window or anything else. what i used is what i call plumbers tape or metal strap, have no clue what its really called. googled it and ace was in the shoping results
here is a link to ace hardware.
https://www.acehardware.com/departments/plumbing/parts-and-repair/pipe-hangers-and-straps/4208674?x429=true&gclid=CjwKCAiA6seQBhAfEiwAvPqu1xO0m00cqcHL57G-BF6stdXiW8RY2zIqmIcmuK9hEBYKfRrijJ1bgBoCCpIQAvD_BwE&gclsrc=aw.ds
