Recording
reevesr19
I am wanting to connect a digital voice recorder to record call signs, names and local data on contacts made while on the GMRS & HAM bands. I have seen pigtail setups that are used in aviation to record pilot and tower transmissions.
Has anybody setup something like this that might share some ideas. I have some hearing loss from to much 2nd amendment fun & work in the early years and sometimes need to have operators go phonetic and slow so I can write things down for my log entry's.
Any ideas would be great.
Ron
WRNX920
KW7RNX
4 answers to this question
  • 2
Ron
WRNX920
KW7RNX
i would imagine a simple headphone splitter would work, if you have a recorder with a 3.5mm input; feed the other side of a splitter to an external speaker, and good to go.  alternately, some fiddling in the settings could probably work to feed the audio into a pc and have it both record and play through the speakers.
i currently have my two base radios fed into a y connector (meant as a splitter, but i'm using it to combine), which then feeds either a pair of computer speakers through their harness, or into a headphone amp and headphones (cuts the volume level for late night listening).
7 hours ago, alexd51 said:
thank you @reevesr19 i was just thinking about asking this myself. I have a digital recorder and i will try this , hopefully it doesn't cut the start of a conversation because to save batteries it will go to sleep until it hears something.
I have watched a number of POTA & SOTA videos and they are running the radio audio out to the recorder and then putting a head set on the earphone output of the recorder to monitor it. It may work out to a speaker also.
I will see what I can get working and what I used when I am happy with it.
WRNX920
POTA- Parks on the Air
SOTA-Summits on the Air
