Guest HunterMike Posted February 28, 2022 Report Posted February 28, 2022 Is it possible to connect the antenna of a gmrs radio away from the radio (60 ft) Quote
wayoverthere Posted March 1, 2022 Report Posted March 1, 2022 48 minutes ago, Guest HunterMike said: Is it possible to connect the antenna of a gmrs radio away from the radio (60 ft) Absolutely. There's considerations on routing, type of cable, and power loss in the cable to account for along the way, but overall, yes it can be done, as long as your radio has a removable antenna. PACNWComms 1 Quote
PACNWComms Posted March 1, 2022 Report Posted March 1, 2022 13 hours ago, wayoverthere said: yes it can be done, as long as your radio has a removable antenna. +1 on this.....but then there is the joke, just because you can do something, doesn't mean that you should do something. I once saw in the military, a Marine connect about 100 feet of RG-58 coax onto an Icom IC-F43GS handheld radio. Upon further inspection, I noticed it was not even a continuous length of coax, but several lengths of RG-58 with BNC connectors and barrel adapters in between each segment (and adapter at the antenna connection to the radio). He wondered why he could not hear anyone or get out during transmit. This became a training moment on radio theory and coax line loss. gortex2, wayoverthere, PRadio and 1 other 4 Quote
Guest HunterMike Posted March 2, 2022 Report Posted March 2, 2022 On 2/28/2022 at 7:46 PM, wayoverthere said: Absolutely. There's considerations on routing, type of cable, and power loss in the cable to account for along the way, but overall, yes it can be done, as long as your radio has a removable antenna. Thanks a lot Quote
