paulw Posted April 16, 2022 Report Posted April 16, 2022 I am currently unsure and was curious to know if anyone knew if using a 50 Watt radio in combination with a 10 Watt repeater would be legal? The reason I’m asking is because 50 Watts is the maximum power output allowed. So, does the repeater count as the amount of wattage or not? Thanks! Quote
SteveShannon Posted April 16, 2022 Report Posted April 16, 2022 They don’t sum. The output of the radio is considered separately from the output of the repeater. But if you can contact the repeater with your 50 watt radio turned down to 5 watts, you should. WRPC505 and AdmiralCochrane 2 Quote
