WRQE264 Posted April 24, 2022 Report Posted April 24, 2022 Good morning! I realize I’m new. I lurked for a while then got my license and now a HT. The uv-9g seems like quite a capable starter radio. The only real drawback I’ve found is the belt clip. Who on earth ok’d that design? Does anyone know of a company that makes any sort of kydex holster or clip set up? I’ve seen some things for the uv5 just not the 9g. thanks! john Quote
kerstuff Posted April 24, 2022 Report Posted April 24, 2022 Spectre makes some great radio carry gear. I Quote
WRPL668 Posted April 24, 2022 Report Posted April 24, 2022 WRQE264 I own the same radio an I haven’t had the courage to try the belt clip yet. Yes it’s strange but the radio is a great starter radio for the price an so far I’ve overlooked the clip. If you get a decent replacement let me know. I have the extended antenna the Nagora 771G and I’d rather not use the current clip. Good luck. bob - WRPL668 WRPE755 1 Quote
WRVP693 Posted January 7, 2023 Report Posted January 7, 2023 I know I'm coming in kinda late with this but I just recently got into GMRS radios. Bought me a Baofeng UV-9G and absolutely hated that included belt clip! Here comes 3D printing to the rescue! Found a design I liked on Thingiverse that someone had made for a Yaesu radio and got to work in Tinkercad to modify it to work with the UV-9G. A couple iterations later and I now have a belt clip that I'm quite happy with. WSAK531, WRKC550 and ZGPilot1955 3 Quote
Lscott Posted January 7, 2023 Report Posted January 7, 2023 Ah, the magic of 3-D printing. We have a 3-D printer in our engineering department. We don't use ordinary plastic thread. Instead, I'm told, it's a more expensive carbon fiber type for extra strength. For things like belt clips you might want to look into that. Also you have to watch out which direction the layers are put down verses the forces applied. Plastic printed parts have failed along the boundaries between layers, they don't bond that well. A few suggestions have been made where people have put the finished part in an oven to get the plastic temperature up where it will bond better at the layer boundaries then let it cool back down. Knilc and WRUS537 2 Quote
WRVP693 Posted January 8, 2023 Report Posted January 8, 2023 These were printed on their sides so the layer lines wouldn't be an issue with the force that would be applied. I've been 3D printing for years and have definitely learned that the hard way from having many things break. The most common filament used is PLA which doesn't hold up to the heat and sun of summertime and would soften and deform the part. I printed a belt clip for my used Uniden SDS100 scanner that i got years ago with PETG (has a higher melting point so it won't soften) and it's been holding up great. This clip was also printed with PETG. Haven't run across a need for any carbon filament yet, but who knows what the future will bring. Quote
MEHoffman169 Posted January 17, 2023 Report Posted January 17, 2023 Anyone made these 3D printed belt clips available for purchase? Quote
WRVP693 Posted January 18, 2023 Report Posted January 18, 2023 14 hours ago, MEHoffman169 said: Anyone made these 3D printed belt clips available for purchase? If you want to contact me at wrvp693@gmail.com we could probably work something out and I can make one for you. WSAK531 and WRKC550 2 Quote
