So I had this interesting idea while looking at some "Tactical" repeaters owned by the Texas Department of Transportation. Basically they are VHF boxes with Li-on battery packs about the size of your average Pelican handgun case, a 5W full duplex board and a notchplexer.
Then I started running some power draw numbers with the Maxon data radios…then the Ritron data radios, and then Tecnet released a new line of smaller data radios along side their Maxon line at IWCE this year.
Then 11 Motorola RNet 450's plopped in my lap from a SK's estate. Crystal controlled, single channel data radios that'll run 4W out (on what is probably a 10% duty cycle) with some other junk in the case that isn't actually needed for "repeater" duty.
So I've though about throwing a repeater (or two) together in an ammo can, adding a small duplexer (the 20W rated Jensen duplexer will fit nicely in a 30 cal can), adding some external heat sinking and a battery and seeing how it runs. Just gotta track down the service manual for the radios if I'm going to use the RNet radios…
zap
Any thoughts?
12 answers to this question
