I have been working on this for a few months now, and I am close to being online. I have emailed Rich many times and my last few emails requesting the same help (despite buying everything from him) have fallen on deaf ears...
I can't seem to find much using the search... under the user, there is a section for Node managment. I don't have anything listed, is there suspost to be something?. I am finding conflicting information on correct DTMF procedure... I have looked in my rpt.con file and it shows *1 disconnect *3 connect. I will hold the PTT and press *3177 to connect to the intermountian hub. once I complete this I then *70 and I get nothing about being connected, only says monitoring. I do *85 and get the IP address. Also the node will say the time every hour over the repeater... But I can't seem to connect to any Nodes... I have set port 4569 to forward in the router as per the quick start guide. I then wanted to check if the DTMF was being recevied correctly, under run asterisk CLI client when I test the DTMF I get a hangup after every number pushed, shouldn't this be seemless and only show a hangup after the PTT has been released?. Thanks for any help that can be offered!
WRKV653
Admin for Node 21605 and Seeksafety repeater
WRKV653
4 answers to this question
