Baofeng UV-82 (Classic, 5W) + RIM Lite Node Radio
So, I've been trying to setup a small Allstarlink network. I was looking for a source that I could purchase a modified USB sound FOB. Not much luck there and my micro-soldering skills are not so great. I just don't have the eye sight to do this.
I contacted Repeater-Builder and asked if he had anything or knew anyone that had anything like what I needed. He said he felt sure his RIM Lite would work. I told him I could do the radio part of the soldering. I also showed him a pic of one of the guys node radio that I will be connecting to with his Maxtrac board on a Baofeng 888. He still said he thought the RIM lite was the better way to go.
So, I got the board and the radio soldered up. I tried using simpleusb but it's not working. Error messages show the connection to the RIM Lite dies, reconnects and dies, over and over. I tried the usbradio setup but have errors there as well.
Simpleusb:
[Oct 26 10:30:45] WARNING[3421] chan_simpleusb.c: Loaded parameters from simpleusb_tune_usb_1501.conf for device usb_1501 .
[Oct 26 10:30:45] WARNING[3420] chan_simpleusb.c: Possibly stuck USB read channel. [usb_1501]
[Oct 26 10:30:45] WARNING[3420] chan_simpleusb.c: Nope, USB read channel [usb_1501] wasn't stuck after all.
Usbradio:
[Oct 27 05:51:05] WARNING[1088] channel.c: Exception flag set on 'Radio/usb_1501', but no exception handler
From the Allstarlink WIKI on modifying the UV-82, to the DB-9 on the RIM Lite:
PIN
2 =====> Mic In (RX)
3 =====> COS
5 =====> PTT
6 =====> Audio Out (TX)
8,9 ====> Gnd
Hopefully someone here can help. I can't post my questions on Allstarlink.org as I'm not a Ham and no response from Repeater-Builder. I'm close, but no cigar.
TIA
1 hour ago, MichaelLAX said:
Just curious: how will you use an Allstar network if you are not a Ham?
Not planning to use the Allstarlink network per se. myGMRS uses it to run their netowork. Just a few modifications are all that are needed to setup a small group of nodes. You don't need a registration server.
