Guest WRVY696 Posted January 28, 2023 Report Posted January 28, 2023 Decode/ encode on the digital private line ( dpl265); on the drop down menu, is there a difference between d265n and d265i ? My radio is a radioddity db20-g. Forgive my lack of knowledge, it's my first day. Chris Quote
wayoverthere Posted January 28, 2023 Report Posted January 28, 2023 29 minutes ago, Guest WRVY696 said: Decode/ encode on the digital private line ( dpl265); on the drop down menu, is there a difference between d265n and d265i ? My radio is a radioddity db20-g. Forgive my lack of knowledge, it's my first day. Chris Yes, the N and the I specify "normal" or "inverted" version of the digital tone. Usually if the letter is omitted, "normal" is assumed. At worst, if one doesn't work, switch to the other. WRUU653, FlatTop and SteveShannon 3 Quote
Guest WRVY696 Posted January 28, 2023 Report Posted January 28, 2023 thankyou!! , I have several of the closest repeaters programmed,4 of the 6 ihave programmed use DPL 265 and its hard to find any useful information, outsde of the forum. Chris Quote
WRQI583 Posted January 30, 2023 Report Posted January 30, 2023 In my over 30 years of radio, what I have found is that the NORMAL version of the tone is what is always used, so its best to go with that first. There are many articles online that explain the difference between normal and inverted if you google them. Quote
Radioguy7268 Posted January 30, 2023 Report Posted January 30, 2023 ... and you will also find out that every normal DPL code has (at least 1) matching invert, which is really just another number on the DPL chart. So folks who (over)think it and decide that they're getting some type of super special "secure access" on their repeater by choosing some odd-ball Inverted code end up baffled when someone sniffs out their code over the air within 30 seconds. Inverted code/matching std code 023 047 025 244 026 464 031 627 032 051 036 172 When you're dealing with digital ones and zero's in a streaming bit code, the patterns end up repeating themselves, even if your bitstream originally started with a 0 instead of a 1. Someone with more patience and knowledge explained it better than me, but if you want to go for a deep dive - here it is: DPL demystified WRUU653, wayoverthere and PACNWComms 2 1 Quote
