Wannabe Posted February 26, 2023 Report Posted February 26, 2023 Just recently got my GMRS license and joined this group, and now I need to get into a radio (Ive been using a UV-5R as a "scanner only" and something to learn to program on). The radios that I have been looking at are the BTech GMRS pro and the Retevis RT29. I like the big color screen and the bells and whistles of the PRO, and a few guys in my close group are using them, but I like the power and price of the RT29 (I can buy 2 RT29's for the price of one BTech Pro) looking for advice on why one would be better than the other. (I know the Retevis is not Part 95, it would be for "scanning only" and SHTF/emergency comms) Thanks in advance! Quote
WRUU653 Posted February 27, 2023 Report Posted February 27, 2023 14 hours ago, Wannabe said: Just recently got my GMRS license and joined this group, and now I need to get into a radio (Ive been using a UV-5R as a "scanner only" and something to learn to program on). The radios that I have been looking at are the BTech GMRS pro and the Retevis RT29. I like the big color screen and the bells and whistles of the PRO, and a few guys in my close group are using them, but I like the power and price of the RT29 (I can buy 2 RT29's for the price of one BTech Pro) looking for advice on why one would be better than the other. (I know the Retevis is not Part 95, it would be for "scanning only" and SHTF/emergency comms The black one, get the black one. No the one on the left… but seriously they are two completely different animals. Sure they’re both radios but it’s like saying should I get a Jeep or a motorcycle. I don’t know, what do you want to do? But as you have a license for one maybe that will inform your decision. You will need to figure out what it is you want to do with the radio. Or get both SteveShannon 1 Quote
Wannabe Posted February 27, 2023 Author Report Posted February 27, 2023 Can you recommend a radio with higher power that won’t disappoint? The main reason I was leaning towards the Retevis was the power. Quote
SteveShannon Posted February 27, 2023 Report Posted February 27, 2023 57 minutes ago, Wannabe said: Can you recommend a radio with higher power that won’t disappoint? The main reason I was leaning towards the Retevis was the power. One of the things that you’ll quickly learn, either by recommendation here or by use there, is that power is highly overrated as a predictor of range. A good receiver that has both sensitivity and selectivity and a good antenna are much much more important than getting an 8 watt output radio versus a 5 watt radio. TNFrank, WRUU653 and WRVU381 3 Quote
zzz Posted February 27, 2023 Report Posted February 27, 2023 Just now, Sshannon said: One of the things that you’ll quickly learn, either by recommendation here or by use there, is that power is highly overrated as a predictor of range. A good receiver that has both sensitivity and selectivity and a good antenna are much much more important than getting an 8 watt output radio versus a 5 watt radio. Is the difference between 5 watt and 8 watt even noticeable? Quote
SteveShannon Posted February 27, 2023 Report Posted February 27, 2023 1 minute ago, zzz said: Is the difference between 5 watt and 8 watt even noticeable? Not usually. Possibly in thick vegetation, but it’s really not enough extra power to make a difference for most circumstances. In free space quadrupling the power might get you twice the range. Free space means there’s absolutely nothing between the two stations. UHF is primarily line of sight and increasing power doesn’t change the curvature of the earth or remove other physical obstacles. Quote
Wannabe Posted February 27, 2023 Author Report Posted February 27, 2023 51 minutes ago, zzz said: Is the difference between 5 watt and 8 watt even noticeable? I thought the RT29 was a 10 watt unit? Is 5 watt - 10 watt also not that noticeable? Was thinking it would have more power to get through urban areas. Quote
SteveShannon Posted February 27, 2023 Report Posted February 27, 2023 It is rated at 10 watts, but I still think you’ll be surprised at the slight difference in range. Urban areas are difficult. Are you planning on using it on GMRS? Or maybe I ought to ask how you’re planning to use it and what kind of range you hope to get? On the seven interstitial 462 MHz channels you’re limited to 5 watts on a handheld. On the seven interstitial 467 MHz channels you’re limited to 0.5 watts PEP. I would be looking at something like the Wouxun KG-935 for GMRS. WRUU653 1 Quote
jbkalla Posted February 27, 2023 Report Posted February 27, 2023 23 minutes ago, Sshannon said: It is rated at 10 watts, but I still think you’ll be surprised at the slight difference in range. Urban areas are difficult. Are you planning on using it on GMRS? Or maybe I ought to ask how you’re planning to use it and what kind of range you hope to get? On the seven interstitial 462 MHz channels you’re limited to 5 watts on a handheld. On the seven interstitial 467 MHz channels you’re limited to 0.5 watts PEP. I would be looking at something like the Wouxun KG-935 for GMRS. On the plus side, the Wouxun radios have been tested by either bettersaferadios or buytwowayradios (can't remember which) and the wattage matches what they state. I really like the KG-935G as well. If you don't want to spend so much, the KG-916 is supposed to be decent (and has a superheterodyne receiver!). Even cheaper are the KG-905 and KG-805 radios, both with superhet. The KG-S88G has IP7 waterproofing. The KG-UV9GX is probably the most featured radio. SteveShannon 1 Quote
zzz Posted February 27, 2023 Report Posted February 27, 2023 Does anyone know of any plans to integrate USB-C charging into the KG-UV9GX? or into a compatible battery? Quote
bd348 Posted February 27, 2023 Report Posted February 27, 2023 1 hour ago, zzz said: Does anyone know of any plans to integrate USB-C charging into the KG-UV9GX? or into a compatible battery? If your radio uses a battery which matches one of the ones mentioned here, this battery may work: Wouxun 2600mAh USB-C Battery Pack Quote
WRUU653 Posted February 28, 2023 Report Posted February 28, 2023 4 hours ago, zzz said: Does anyone know of any plans to integrate USB-C charging into the KG-UV9GX? or into a compatible battery? They don’t have one yet for that radio. Quote
