marcspaz Posted April 17, 2023 Report Posted April 17, 2023 This is kind of fun. Today, I made a new setup for operating in the field. I assembled two 25' masts from a 31' mast and a 19' mast, and strung the main element of a homemade OCF 80m antenna between them. The small element tapers off on a slant, with a rope staked in such a way that the end of the short element is about 5' off the ground. Both masts are also setup to receive vertical VHF/UHF antennas. So, I can work Amateur HF, VHF/UHF and GMRS all from one massive setup. I plan on putting this into operation for a 24 hour race I am doing communications for. I'll probably be up for 30 hours with at least 26 of them on the air. So, I'll find out just how good of an 80m NVIS and 10m-20m DX antenna this setup is. If it works well, this will be my Field Day setup. I'll shoot some pictures and video from the race to share later. rivrrat, SteveShannon, kidphc and 1 other 4 Quote
labreja Posted April 17, 2023 Report Posted April 17, 2023 marcspaz, That's really cool! What tripods are you using? Thanks James Quote
marcspaz Posted April 17, 2023 Author Report Posted April 17, 2023 @labreja one tripod is the MFJ-1921, which is 6.5' tall and has an 8' diameter base. That one is holding most of the weight. The other is an MFJ-1919, which is 4.5' tall with a 6' base. Quote
