WRXB215 Posted August 10 Report Share Posted August 10 I was given a Kenwood TH-75A yesterday. No battery, charger, or antenna. Could use some help finding a good place to get these items. Thanks. Quote Link to comment Share on other sites More sharing options...
Lscott Posted August 10 Report Share Posted August 10 Schematic http://static2.rigreference.com/manuals/kenwood/kenwood-th-75-schematic-diagram.pdf Service Manual http://static2.rigreference.com/manuals/kenwood/kenwood-th-75-service-manual.pdf User Manual http://static2.rigreference.com/manuals/kenwood/kenwood-th-75-user-manual.pdf The manuals have the Kenwood part numbers you need. Then try searching on places like ebay for them. WRXB215 1 Quote Link to comment Share on other sites More sharing options...
Sshannon Posted August 10 Report Share Posted August 10 Good luck in your quest. I read the title and thought it was about the new Kenwood handheld which has a very similar name TH D75A: WRYQ788 and WRXB215 2 Quote Link to comment Share on other sites More sharing options...
WRXB215 Posted August 10 Author Report Share Posted August 10 @Lscott Thanks for the docs. @Sshannon Mine is a little older than that. Quote Link to comment Share on other sites More sharing options...
KAF6045 Posted August 10 Report Share Posted August 10 2 hours ago, WRXB215 said: I was given a Kenwood TH-75A yesterday. No battery, charger, or antenna. Could use some help finding a good place to get these items. https://batteriesamerica.com/products/pb-6xe?pr_prod_strat=use_description&pr_rec_id=0aaccb041&pr_rec_pid=402679693343&pr_ref_pid=402674057247&pr_seq=uniform https://batteriesamerica.com/products/pb-6wc?pr_prod_strat=copurchase&pr_rec_id=d09bc613e&pr_rec_pid=402674679839&pr_ref_pid=402679693343&pr_seq=uniform https://batteriesamerica.com/products/ksc-14?_pos=1&_sid=c4469b717&_ss=r What type of antenna connector does it have? For that age, likely a BNC. Pretty much ANY 2m/70cm BNC antenna should be compatible. WRXB215 1 Quote Link to comment Share on other sites More sharing options...
WRXB215 Posted August 10 Author Report Share Posted August 10 58 minutes ago, KAF6045 said: What type of antenna connector does it have? For that age, likely a BNC. Yes, it is BNC. Quote Link to comment Share on other sites More sharing options...
