Guest Shane Posted October 5, 2023 Report Posted October 5, 2023 This is a little weird. I have two Baofeng UV – 5G. And 2 Midland x talk gmrs radios. The Midland is set to. Channel 20 and the UV – 5G is set to the corresponding. Frequency which I think is 462.675. Anyway, the two Midlands will talk to each other and the Midlands will talk to the two UV- 5g but the two UV 5G will not communicate with each other, and will not communicate with the Midland. I don’t get it. Any ideas? Quote
WRXB215 Posted October 5, 2023 Report Posted October 5, 2023 The first thing I would do is check the tones. Start by removing them all and then if you want to use tones, make sure they are the same on all radios. WRHS218 and SteveShannon 1 1 Quote
ShaneF Posted October 6, 2023 Report Posted October 6, 2023 I will try that but the issues is i can talk FROM the midlands but not from the UV-5g Quote
Tico Posted October 6, 2023 Report Posted October 6, 2023 12 hours ago, Guest Shane said: This is a little weird. I have two Baofeng UV – 5G. And 2 Midland x talk gmrs radios. The Midland is set to. Channel 20 and the UV – 5G is set to the corresponding. Frequency which I think is 462.675. Anyway, the two Midlands will talk to each other and the Midlands will talk to the two UV- 5g but the two UV 5G will not communicate with each other, and will not communicate with the Midland. I don’t get it. Any ideas? Someone mention about this issue when one radio is using wide band and the other narrow band check it out and let us know. WRXB215 1 Quote
OffRoaderX Posted October 6, 2023 Report Posted October 6, 2023 Wide/Narrow has nothing to do with it because that would not prevent them from transmitting/hearing each other. The issue is he is trying to transmit in frequency/VFO mode, which you cannot do on UV-5G radios.. Assuming there are no incorrect tones, putting the radio in channel/MR mode and set the correct GMRS "channel" should make everything work. WRXB215, WRYC373, WashingtonMatt and 1 other 4 Quote
ShaneF Posted October 6, 2023 Report Posted October 6, 2023 Thanks it worked Both radios are in channel mode and working Tico, OffRoaderX and SteveShannon 1 2 Quote
Guest Wrzt743 Posted December 14, 2023 Report Posted December 14, 2023 Your baofengs might be locked from transmitting on gmrs Quote
OffRoaderX Posted December 14, 2023 Report Posted December 14, 2023 1 hour ago, Guest Wrzt743 said: Your baofengs might be locked from transmitting on gmrs He already confirmed that the issue was resolved from a previous comment The radio he specified, the UV-5G, is designed specifically TO transmit on GMRS. Nice effort though .. I guess? WRXB215 and WRZU658 2 Quote
WRZT743 Posted December 15, 2023 Report Posted December 15, 2023 I some how missed his response saying he fixed the problem. OffRoaderX - Just wanted to say thanks for all your videos, they have helped with allot of my own questions... FYI Your sense of humor is great. WRXB215 1 Quote
Guest Bob WRZP358 Posted December 15, 2023 Report Posted December 15, 2023 19 hours ago, OffRoaderX said: He already confirmed that the issue was resolved from a previous comment The radio he specified, the UV-5G, is designed specifically TO transmit on GMRS. Nice effort though .. I guess? I like the post, and comments you post, I have learned a lot about GMRS from you do a great job, for the new GMRS operators, I have been the whole rout in radio, I started in radio as a CBer, I be came to Ham Radio operator, and now I add GMRS, To me its all about talking to new people, when ever thing goes South all radio will be needed. Thanks and keep up the great work, Randy. Quote
Guest despair Posted January 8, 2024 Report Posted January 8, 2024 mg shinny new uv 5g plus will not save or delete channles no matter what firmware baofeng will not edit. thrown it in the bin Quote
WRXB215 Posted January 8, 2024 Report Posted January 8, 2024 @Guest Send it back for a replacement. SteveShannon 1 Quote
Guest Rommel Posted June 29, 2024 Report Posted June 29, 2024 On 12/14/2023 at 3:17 PM, OffRoaderX said: He already confirmed that the issue was resolved from a previous comment The radio he specified, the UV-5G, is designed specifically TO transmit on GMRS. Nice effort though .. I guess? My new UV-25 is not transmitting after a factory reset. Maybe it is locked from transmitting in GMRS? I don't know. Can you please give some advice about this? Quote
OffRoaderX Posted June 29, 2024 Report Posted June 29, 2024 29 minutes ago, Guest Rommel said: Can you please give some advice about this? My advice is to create a new topic/thread instead of necroposting on this one, which is about a totally different radio. kirk5056 1 Quote
