WRZM344 Posted December 11, 2023 Report Posted December 11, 2023 chirp does NOT have Baofeng GMRS 9R listed, so i can't make a backup of the factory settings. Help please. I did download chirp Next since some one on other forum mention it supports the new GMRS radios and does not Quote
Guest Posted December 11, 2023 Report Posted December 11, 2023 Use the UV-9R or UV-9G models, one of those will work just fine (don’t recall which, not near my desk). Quote
WRYZ926 Posted December 11, 2023 Report Posted December 11, 2023 Did you select UV9R or UV9G and did you select the proper com port? WRUU653 1 Quote
WRXB215 Posted December 12, 2023 Report Posted December 12, 2023 You can also use the Baofeng software to back the factory settings until you figure out which one to select in CHIRP. Quote
FlatTop Posted December 12, 2023 Report Posted December 12, 2023 Pretty sure the 9R is an updated UV5R except for GMRS and IP67 waterproof...might try the UV5R/G in CHIRP. Baofeng models happen about 20 a week...so it takes time for CHIRP to catch up. Quote
WRYS709 Posted December 12, 2023 Report Posted December 12, 2023 I do not have this model, but... I googl'd "Baofeng-9R" and got this website. I then clicked "Download" and got this website. There is no model "GMRS-9R" listed on the Downloads page, but there is a "UV-9R." Is this the same radio? Attached below, is the downloaded Manual for the "UV-9R": That same page also has a software download for the "UV-9R", also attached below for ease of use: Try this software and see if you can make a copy of the default settings and report back your results for others. GOOD LUCK! BAOFENG_UV_9R_User_Manual_20231019_EN.pdf WP970I_ENG_CPS.CAB SETUP.LST setup.exe WRYQ631 1 Quote
WRYZ926 Posted December 13, 2023 Report Posted December 13, 2023 I have the Baofeng UV-5R GMRS and I have to choose the Radioddity UV-5G when using CHIRP Quote
WRPL700 Posted December 13, 2023 Report Posted December 13, 2023 I was going to answer this yesterday, but did not because I thought it was clear... I also have the GMRS-9R (two purchased on Amazon). I use chirp and you should use the Baofeng UV-9G setting. It works perfectly. WRYZ926, WRYQ631 and WRUU653 3 Quote
WRYQ631 Posted January 4, 2024 Report Posted January 4, 2024 Don't forget to fix channel 15. The .kdh file is in the .zip within the .zip. Silly I know but that how they did it. Baofeng_UV-9G_Update_Transmit_on_Channel_15_202311.zip Quote
WRYS709 Posted January 4, 2024 Report Posted January 4, 2024 On 12/13/2023 at 4:11 AM, WRPL700 said: I was going to answer this yesterday, but did not because I thought it was clear... I also have the GMRS-9R (two purchased on Amazon). I use chirp and you should use the Baofeng UV-9G setting. It works perfectly. This may be a Ghost Thread: the OP joined and posted on December 11, 2023 and has never returned... Quote
