chirp does NOT have Baofeng GMRS 9R listed, so i can't make a backup of the factory settings.  Help please. I did download chirp Next since some one on other forum mention it supports the new GMRS radios and does not
Use the UV-9R or UV-9G models, one of those will work just fine (don’t recall which, not near my desk).
I do not have this model, but...
I googl'd "Baofeng-9R" and got this website.
I then clicked "Download" and got this website.
There is no model "GMRS-9R" listed on the Downloads page, but there is a "UV-9R." Is this the same radio?
Attached below, is the downloaded Manual for the "UV-9R":
That same page also has a software download for the "UV-9R", also attached below for ease of use:
Try this software and see if you can make a copy of the default settings and report back your results for others.
GOOD LUCK!
BAOFENG_UV_9R_User_Manual_20231019_EN.pdf WP970I_ENG_CPS.CAB SETUP.LST setup.exe
  • 4 weeks later...
On 12/13/2023 at 4:11 AM, WRPL700 said:
I was going to answer this yesterday, but did not because I thought it was clear...  I also have the GMRS-9R (two purchased on Amazon).  I use chirp and you should use the Baofeng UV-9G setting.  It works perfectly.
This may be a Ghost Thread: the OP joined and posted on December 11, 2023 and has never returned...
Reply to this topic...
