WRZM243 Posted December 26, 2023 Report Posted December 26, 2023 (edited) When measuring the height of an outdoor antenna from the ground up, is it measured only to the the base of the antenna or the tip top of the antenna? The measurement is for entering into myGMRS for adding into the height section for a GMRS Repeater. Edited December 26, 2023 by WRZM243 Clarification Quote
0 tweiss3 Posted December 26, 2023 Report Posted December 26, 2023 Depends on what the measurement is for. If you are modeling the RF horizon, you go from the bottom of the antenna. If you are dealing with zoning, then top of the antenna. WRYZ926, SteveC7010, tcp2525 and 2 others 5 Quote
WRZM243
Clarification
1 answer to this question
