WRYF747 Posted January 16, 2024 Report Posted January 16, 2024 What is allowed and not allowed with duplexing? Can I reverse normal GMRS duplexing (467 as input, 462 as output) like an LMR repeater? Quote
0 SteveShannon Posted January 16, 2024 Report Posted January 16, 2024 50 minutes ago, WRYF747 said: What is allowed and not allowed with duplexing? Can I reverse normal GMRS duplexing (467 as input, 462 as output) like an LMR repeater? Not on the repeater: 462 MHz main channels. Only mobile, hand-held portable, repeater, base and fixed stations may transmit on these 8 channels. The channel center frequencies are: 462.5500, 462.5750, 462.6000, 462.6250, 462.6500, 462.6750, 462.7000, and 462.7250 MHz. 467 MHz main channels. Only mobile, hand-held portable, control and fixed stations may transmit on these 8 channels. Mobile, hand-held portable and control stations may transmit on these channels only when communicating through a repeater station or making brief test transmissions in accordance with § 95.319(c). The channel center frequencies are: 467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000, and 467.7250 MHz. WRUU653 and wrci350 2 Quote
0 WRYF747 Posted January 17, 2024 Author Report Posted January 17, 2024 What are control and fixed stations? Quote
0 SteveShannon Posted January 17, 2024 Report Posted January 17, 2024 5 minutes ago, WRYF747 said: What are control and fixed stations? Control station. A station at a fixed location that communicates with mobile stations and other control stations through repeater stations, and may also be used to control the operation of repeater stations. Fixed station. A station at a fixed location that directly communicates with other fixed stations only. WRUU653 and WRYF747 2 Quote
0 marcspaz Posted January 17, 2024 Report Posted January 17, 2024 Not only is it not allowed (as normal practice), the only way to use the repeater in that configuration would be to use non-type approved hardware or otherwise type approved hardware with a configuration that invalidates its certification and legal use. So, it would be a double no. WRUU653, Pjshaw, SteveShannon and 2 others 5 Quote
WRYF747
4 answers to this question
