Poor recieve quality in new mobile rig
Hello everyone,
I just installed a KG-XS20g with a Wouxun ANO-050G Mobile GMRS Antenna in my truck. I get good signal report when transmitting to the local repeater but, when I am recieving a signal however, it sounds choppy. I did have to solder in the connector for that antenna so I am, I guess, concerned I may not have done a good job on that. Is there any other possiblities before I redo that connector?
5 answers to this question
30 minutes ago, WSAB905 said:
Hello everyone,
Is it while you’re moving or parked that it’s choppy?
It could be a loose connection with the coax or a bad solder job. I had an issue where the tiny connector on my mag mount coat was a little loose where it connects to the PL259 connecter. I didn't notice an issue unless I was hitting bumps while driving.
I suggest double checking your solder job and making sure everything is tight from the antenna to the radio.
