Baofeng UV5G /Chirp
I just picked up a set of these and I am trying to set up a repeater.  I have other radios and I have no problem setting up the repeater on the keypad or through the software. Here is my issue.  If I use the radio keypad to manually enter the R-CTCS code and then hit Menu button again (save confirmed)however,  when I go back and check it says R-CTCS is off.  I tried numerous time and it did not save.   Now if I  program the code (s) with CHIRP it will save it.  Is this a problem with the radio or am I doing something wrong?
Thank  you..
3 answers to this question
