Guest patcrabb@yahoo.com Posted February 11, 2024 Report Posted February 11, 2024 I have a Wouxun KG100G Some how I have changed it to read Frequency mode instead of Channel mode. I have reviewed the manual several times and I can not find how to change it back to channel mode. Any help would be greatly appreciated Thank you in advance Pat Crabb WROH901 Patcrabb@yahoo,con Quote
OffRoaderX Posted February 11, 2024 Report Posted February 11, 2024 Try tapping the '6' button. SteveShannon, WRWE456 and WRUU653 3 Quote
WRYZ926 Posted February 11, 2024 Report Posted February 11, 2024 Here is a photo of the KG-1000-G mic. Quote
WRWE456 Posted February 11, 2024 Report Posted February 11, 2024 I have the KG-1000G Plus. Renaming that button must be one of the changes made to the new model. Quote
WRYZ926 Posted February 12, 2024 Report Posted February 12, 2024 6 hours ago, WRWE456 said: I have the KG-1000G Plus. Renaming that button must be one of the changes made to the new model. That is the mic that came with my KG-1000G. I also have a KG-1000G Plus. The mics are identical. Quote
WRWE456 Posted February 12, 2024 Report Posted February 12, 2024 Interesting. Here is a link to it. if you scroll through the photos you will see the mic close up. https://www.buytwowayradios.com/wouxun-kg-1000g-plus.html WRYZ926 1 Quote
WRYZ926 Posted February 12, 2024 Report Posted February 12, 2024 I stand corrected and I need to pay closer attention to my radios. I went out and took a photo of my KG1000G Plus mic and it is labeled differently. I never paid attention to the labels when swapping the mics between the two radios. Either way it is button 6 that you use to change from frequency, channel number, or channel name. WRWE456 1 Quote
