WSAA635 Posted February 18, 2024 Report Posted February 18, 2024 True to my High Functioning Autistic Self I have to totally Do Things to Death so I ordered a Baofeng GT-3TP Mark III to play with. That'll bring my totally radio count to 8(2/UV-5R's, 3/UV-82's, 2/KG-UVD1P's and now the GT-3TP Mark III) so I think I'm good for now. Why I wanted this radio is 2(or 3) fold. 1) It seems like a pretty decent radio that's suppose to be rated at 8watts and comes with a pretty decent antenna and a car charger. 2) It'll be my Truck Radio since the higher power should give me a bit better reach(I know that's questionable but hey, a couple extra watts can't hurt) and the car charger will make it easy to keep the radio charged up. 3) The price isn't much($26 bucks) so if it gets stolen I'm not out much. I can use the BF-F8HP Profile in CHIRP to program it and it should unlock the same as the UV-5R radios so I'll get full GMRS and MURS function out of it. I'll do a power test(and probably make a video about the radio) to see if it'll be like the UV-82 where "high" is actually lower power than medium or low which I found to be kind of crazy. Anyway, just wanted to share and see if anyone else has or thought about getting one of these. Talk to ya'll later. Quote
WRUU653 Posted February 18, 2024 Report Posted February 18, 2024 6 hours ago, WSAA635 said: That'll bring my totally radio count to 8 Oh yeah, you got the bug. No known cure at this point. I personally don’t think it’s a problem until you can’t remember what you have and even then I may change my opinion on that. 6 hours ago, WSAA635 said: so I think I'm good for now You’d think but as a collector myself I’m skeptical WRYZ926 1 Quote
WRYZ926 Posted February 18, 2024 Report Posted February 18, 2024 I m finding that radios, especially hand held, is a lot like AR rifles. They seem to multiply all on their own. WRWE456 1 Quote
WSAA635 Posted February 19, 2024 Author Report Posted February 19, 2024 You should have seen the Traditional Pocket Knife kick I was on a few months back. You can see a small sample of them on my YouTube channel videos. I must have at least 75 or 80 of them total. Quote
WRYZ926 Posted February 19, 2024 Report Posted February 19, 2024 I only have 6 HT's. I know rookie numbers Let us know how you like the new radio. Quote
WSAA635 Posted February 19, 2024 Author Report Posted February 19, 2024 12 hours ago, WRYZ926 said: I only have 6 HT's. I know rookie numbers Let us know how you like the new radio. I'll probably do a video on it. I also want to test the 3 power levels to see which is the highest setting. With the UV-82 the "high" setting actually put out less power than the medium and low settings. WRYZ926 1 Quote
WRYZ926 Posted February 19, 2024 Report Posted February 19, 2024 2 minutes ago, WSAA635 said: With the UV-82 the "high" setting actually put out less power than the medium and low settings. That's interesting. I haven't seen that testing my Baofeng (2 UV-5r GRMS and 1 GT-5R), Explorer QRZ1 (TYT UV88), Icom IC-T10, and Wouxun KG-935G HT's. Quote
ULTRA2 Posted February 20, 2024 Report Posted February 20, 2024 On 2/18/2024 at 8:03 AM, WSAA635 said: rated at 8watts Have you put a Watt meter to the Radio and have it confirmed that it transmitting 8 Watts? They say it transmit 8 watts so you be suckered into buying the radio and comes to find out it doesn't transmit the 8 watts it claims to. Quote
WSAA635 Posted February 20, 2024 Author Report Posted February 20, 2024 I just got the radio today. When I get home from work I'll open the box and get it set up then give it a test. Quote
WSAA635 Posted February 20, 2024 Author Report Posted February 20, 2024 Initial testing tonight gave the following readings: Low=2.8 watts Medium=5.18 watts Hight=6.30 watts. I'd think that's pretty close enough since 1.7 watts shouldn't make that much of a difference and it's right in the same ballpark as my UV-82's are. I'm happy with it so far. It unlocks the same as the UV-5R and the Radioddity antenna is a nice upgrade. All in all it's a Baofeng Radio, nothing more, nothing less, decent deal for the money. WRXB215 and WRYZ926 2 Quote
