WSAX322 Posted February 25, 2024 Report Posted February 25, 2024 Hello...just received my Baofeng UV 5g plus today! Can anyone help out on configuring repeaters on this radio? Thanks for any help. arn 1 Quote
OffRoaderX Posted February 25, 2024 Report Posted February 25, 2024 Its very easy: Read manual Identify what Repeater channel your local repeater is on Change radio to the correct repeater channel Enter the correct TX (transmit) CTC or DTC tone for the repeater and save (for questions, refer to item #1) do not concern yourself with the RX/Receive tone until you level-up to "I know what I'm doing now" Hold radio near your noise output hole, & push the talk trigger and talk, then take your finger off the trigger Hold radio near your noise input hole and wait for everyone to congratulate you on a job well-done SteveShannon and WRPG745 2 Quote
WSAH999 Posted February 25, 2024 Report Posted February 25, 2024 1 hour ago, OffRoaderX said: Hold radio near your noise output hole, & push the talk trigger Hold radio near your noise input hole and wait for everyone to congratulate you on a job well-done Ah see, that's where I went wrong, I swapped the input and output hole... rookie mistake. SteveShannon, WRPG745, WRWE456 and 1 other 2 2 Quote
WSAX322 Posted February 25, 2024 Author Report Posted February 25, 2024 OK off roader....after reading the manual...as i always do.....in the section 6.4, repeater programming: the frequency offset and off set direction has me as to what to do next..........give me some credit......... I'm not that new......!!! Quote
WSAH999 Posted February 25, 2024 Report Posted February 25, 2024 1 hour ago, WSAX322 said: OK off roader....after reading the manual...as i always do.....in the section 6.4, repeater programming: the frequency offset and off set direction has me as to what to do next..........give me some credit......... I'm not that new......!!! So for GMRS repeaters. They're going to be on an offset of +5mhz. Repeaters transmit on 462.xxx but receive on 467.xxx Quote
WSAX322 Posted February 25, 2024 Author Report Posted February 25, 2024 ok...what do i input for + - offset direction? Quote
OffRoaderX Posted February 25, 2024 Report Posted February 25, 2024 If you abide by #2 and #3 on my list, you dont need to worry about any of that. WSAH999 1 Quote
WRWE456 Posted February 25, 2024 Report Posted February 25, 2024 True GMRS radios have the offset programed in on the built in repeater channels from the factory. Just follow Randy's instructions above. Quote
WSAX322 Posted February 27, 2024 Author Report Posted February 27, 2024 It is done!!!!! I have overcome the great hurdle of, repeaterf**kunation! I want to thank the both of you for your invaluable information and knowledge. For....i wouldn't have been able to concur this epic task by myself. So with that, i am now able to peruse a happy GMRS life going forward! Ahhhhhh, the noise hole admitter and, the noise hole receiver....is that how its done?....I would have never guessed. arn 1 Quote
