Trying to better understand how and why this tool would be used for my GMRS HT radio. The way I understand it - forgive me if I use the wrong jargon here - the SWR meter is used to test the transmission power of the HT vs the signal gain of the antenna to see how balanced/matched they are? So, a 1:1 ratio is perfect, and anything close to that number is good? What exactly do you call the process for checking that 1:1 ratio, signal to power ratio? I dunno.
Also, when using the SWR meter for testing, what is the purpose of a dummy load? Is that used only when testing transmission power (wattage), or is that used when testing for that 1:1 ratio? Is the dummy load always used with the meter when testing?
Webslinger
Thanks.
Link to comment
Share on other sites
6 answers to this question
