SvenMarbles Posted March 1 Report Share Posted March 1 Is anyone else here running an H8 and randomly have the radio make a beeping tone and then display "P call" on the display? I see nothing in the manual that calls it out. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 2 Report Share Posted March 2 My guess - you have an ANI-ID (PTT-ID on some other brands) set on the handheld,(menu item 39 of the H8, and then are receiving a transmission that is sending that ID as DTMF tones somehow (likely a setting configured to send the PTT-ID on start/end/both sides of the transmission) P call is short for Priority Call and is triggered based on receipt of that ID. NOT the same, but sort of like MDC code function on a Motorola system. Quote Link to comment Share on other sites More sharing options...
SvenMarbles Posted March 2 Author Report Share Posted March 2 14 minutes ago, WRZE995 said: My guess - you have an ANI-ID (PTT-ID on some other brands) set on the handheld,(menu item 39 of the H8, and then are receiving a transmission that is sending that ID as DTMF tones somehow (likely a setting configured to send the PTT-ID on start/end/both sides of the transmission) P call is short for Priority Call and is triggered based on receipt of that ID. NOT the same, but sort of like MDC code function on a Motorola system. That all makes perfect sense, but I never hear any DTMF going out when this happens. Thanks for clarifying what that ANI-ID stuff is though because I never knew really. This will happen just sort of randomly when Ive got the radio on a repeater and chit chat is going on. It just happens sort of randomly.. Quote Link to comment Share on other sites More sharing options...
SvenMarbles Posted March 2 Author Report Share Posted March 2 I should mention too, it's happened very seldomly. Maybe 4 total times in the countless hours that this radio has been operating. It's really not a bother, but more of a curiosity.. I just haven't been able to make any sense of it.. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 2 Report Share Posted March 2 Glad to help - I can directly replicate this by manually sending DTMF tones to my H8 from another radio. When the tones sent match the ANI-ID set on the H8 I get a descending style tone a “P Call ” display on that particular channel. In regard to not hearing the tone, it could be a preamble sent fast enough.. MDC, and especially across repeater sometimes is very hard to discern or hear but the radio picks up and uses it. Basically think of this as something very similar to caller-id on phone systems. Quote Link to comment Share on other sites More sharing options...
