WSBM325 Posted March 6, 2024 Report Posted March 6, 2024 Greetings folks, I’m a newbie. I was trying to determine whether I can reach a certain repeater. I programmed the frequency, off-set and tone into my radio. When I hit the press to talk button, I receive a beep. Can you tell if that is an indicator that contact was made. Thanks Quote
WRYS709 Posted March 6, 2024 Report Posted March 6, 2024 You probably have programmed your radio to beep on the conclusion of your transmission; hence no determination can be made from that beep. Brand/model of Radio? Which Repeater? Other information you think might be relevant, such as the line of sight from your location to the repeater, etc.? Quote
SteveShannon Posted March 6, 2024 Report Posted March 6, 2024 13 minutes ago, WSBM325 said: Greetings folks, I’m a newbie. I was trying to determine whether I can reach a certain repeater. I programmed the frequency, off-set and tone into my radio. When I hit the press to talk button, I receive a beep. Can you tell if that is an indicator that contact was made. Thanks It’s entirely possible that the repeater has a courtesy beep programmed. Some do. If so, you should also hear it whenever anyone else transmits. It’s also possible that your radio is programmed with a Roger beep as 709 suggests. If it’s that it will beep every time you transmit, regardless of the channel. Rather than depending upon the beep, try asking if anyone hears you while you PTT. WRUU653 and WRXB215 2 Quote
WRHS218 Posted March 6, 2024 Report Posted March 6, 2024 What radio are you using? Do you hear the beep while pressing the PTT or after you release it. Some radios will beep if you are trying to TX out of band. WRUU653 and WRXB215 2 Quote
