WSBP830 Posted March 11, 2024 Report Posted March 11, 2024 Trying to program my TD_H8 with RT Sys software. Keeps saying no connection with the radio. Am I missing something. Holding the plug in does not help. Com port is right. Quote
Guest Posted March 11, 2024 Report Posted March 11, 2024 Plug in, turn in radio, hit down load from radio. Is the driver right? Is the cable right for the radio? Quote
WRYZ926 Posted March 11, 2024 Report Posted March 11, 2024 One thing I found is that RT systems does not always play well with aftermarket cables, especially with the Prolific chips. Double check your coms port number in device manager to make sure your computer is seeing it. Then check that you are using the correct com port number in the RT Systems software. Raybestos 1 Quote
WRYS709 Posted March 11, 2024 Report Posted March 11, 2024 41 minutes ago, WRYZ926 said: One thing I found is that RT systems does not always play well with aftermarket cables, especially with the Prolific chips. Many Cables were manufactured with notoriously counterfeited Prolific chips. these are causing many Windows 11 problems. WRYZ926 1 Quote
WSBP830 Posted March 12, 2024 Author Report Posted March 12, 2024 Did the com port thing. PC is seeing it as com port 5. Put that in the drop down in the software. correct cable from RT systems. spoke with her and she is sending me another cable with straight in plug VS the 90 degree one. Quote
WRXB215 Posted March 12, 2024 Report Posted March 12, 2024 1 hour ago, WSBP830 said: she is sending me another cable with straight in plug VS the 90 degree one Apparently electrons have trouble making that 90 degree turn. Raybestos 1 Quote
WSAA635 Posted March 16, 2024 Report Posted March 16, 2024 When I went to DeVry to get my Electronics Technician's Degree (all those years ago) we'd tie knots in wires to slow the flow of electrons. Quote
