UT-72 vs. UT-72G
So, being the impatient person I am I purchased the UT-72 Nagoya antenna without realizing there was a UT-72G which Baofeng is quick to point out for GRMS you need the UT-72G. Not only am I not patient but I am curious as well and "fars" in the Army just made this worse. After reading more on the two antennas I more or less came to the conclusion that the difference between the two was the rod. The other interesting fact is there is no set screw in the UT-72 to remove the rod for tuning.
I went through the channels and found that 1-7 I got an SWR of 1.0 to 1.1. Then 8-14 I was getting 2.2 avg. The repeater channels went up to 1.8 on avg. As mentioned there was no set screw to remove the rod but removing the protective cap on the tip of the rod seemed to work just fine since a little math said I needed it shorter. I cut 5/32 off the tip and retested and came up with 1.0 to 1.1 through all the channels from 1 to 22.
I am pretty convinenced there is loading coil differences between the antenna's or at least they are so closely related that a simple tuning of the rod fixed the issue without going for what now seems like a marketing startegy.
Could someone tell me if I am missing something or if they have encounterd the same issue?
Thanks.
2 answers to this question
  • 2
Posted (edited)
I use the UT-72 for GMRS and have not had a problem with it. A friend and I were talking this morning through a repeater and at one point we hit talk-around for a while. The antenna works quite well for GMRS.
Marketing and manufacturing costs are certainly always in play but keep in mind that the UT-72 is designed/tuned for dual band so the UT-72G should perform better for GMRS than the UT-72.
Edited by WRXB215
Added info.
Thanks for the info.
