I’m intending to use this 3rd light antenna/led light mount/plate for many different antennas. (Pics below)
Will this plate work as properly as a flat solid metal plate used as a plain?(as I have heard of folks using a o sheet.
Next…will multiple antenna installed on this plate or a solid plate cause interference or feedback into a different radio in the same vehicle when multiple radio installed are on ion the same vehicle?
WSAZ909
UPDATE : Radios and antennas to be installed…
Radios being installed:
Radio 1: Abbree AR2520
https://a.aliexpress.com/_mMk93iw
Antenna: Diamond Antenna SG-M507 Dual Band 144/430MHz Mobile Antenna
Radio 2: Wounxun KG-1000G-plus v1
Antenna: BROWNING 450MHz-470MHz UHF 3dBd Land Mobile NMO Antenna https://a.co/d/7fqbE76
or
Midland® MXTA25 3DB MicroMobile® Compatible Gain Ghost Antenna – 3.5” Tall with 1.5” Base Diameter – Low Profile GMRS NMO Connection https://a.co/d/jlFHsxJ
UPDATE ON PLATE SIZE
21” left to right
10.25” front to back
Edited by WSAZ909Measurements of plate, radios, and antennas to be installed
17 answers to this question
