Gnarlykaw Posted April 23, 2024 Report Posted April 23, 2024 I dont remember this column a couple of months ago?? 5.0, 12.5, 25??? is this the same as wide and narrow band on radio?? Quote
SteveShannon Posted April 23, 2024 Report Posted April 23, 2024 18 minutes ago, Gnarlykaw said: I dont remember this column a couple of months ago?? 5.0, 12.5, 25??? is this the same as wide and narrow band on radio?? No, I think it’s going to be the increment of change in frequency when you are in VFO mode and go up or down in frequencies. It isn’t relevant for GMRS. WRXB215, WRHS218 and Sab02r 3 Quote
Gnarlykaw Posted April 23, 2024 Author Report Posted April 23, 2024 So, it makes NO difference of any value thats placed in it? This column just came up in the lastest build. interesting fact though, those values coinside with either narrow band or wide band..... 5 or 12.5.... Quote
OffRoaderX Posted April 23, 2024 Report Posted April 23, 2024 3 minutes ago, Gnarlykaw said: So, it makes NO difference of any value thats placed in it? Yes, it makes a difference if you are in VFO mode and going up or down in frequency. It is not relevant to transmitting on GMRS but it is relevant for receiving frequencies in VFO mode..and tuning up or down in frequency. SteveShannon and WRXB215 2 Quote
SteveShannon Posted April 23, 2024 Report Posted April 23, 2024 10 minutes ago, Gnarlykaw said: So, it makes NO difference of any value thats placed in it? This column just came up in the lastest build. interesting fact though, those values coinside with either narrow band or wide band..... 5 or 12.5.... I didn’t say that it makes no difference. As Randy said it can definitely make a difference in receiving. Also, remember that Chirp is used for many different radios used in different services and the table of data used by Chirp must have a slot for more information than just what’s needed for a GMRS radio. It really depends on the radio features and how they’re implemented. And yes, especially for amateur radios that do not have defined channels, the step size should coincide with the bandwidth of the transmission. Quote
WRXR255 Posted April 23, 2024 Report Posted April 23, 2024 At least that gives you an adjustable stepping ability. My County Comm GP-5/SSB receiver has only two modes I can figure out. Turn the tuning wheel fast, it advances 5 Mhz, slow turn its 1Mhz. and no way to direct input a freq. I need to dig online and find the manual though, I might be wrong. . Quote
SteveShannon Posted April 23, 2024 Report Posted April 23, 2024 1 minute ago, WRXR255 said: At least that gives you an adjustable stepping ability. My County Comm GP-5/SSB receiver has only two modes I can figure out. Turn the tuning wheel fast, it advances 5 Mhz, slow turn its 1Mhz. and no way to direct input a freq. I need to dig online and find the manual though, I might be wrong. . 5 MHz fast and 1 MHz slow? How did you get 28.300 MHz? Or did it start at 0.300 MHz? Quote
WRXR255 Posted April 23, 2024 Report Posted April 23, 2024 1 minute ago, Sshannon said: 5 MHz fast and 1 MHz slow? How did you get 28.300 MHz? Or did it start at 0.300 MHz? My display has no "." so its showing 28300 kHz... I screwed up the MHz / KHz its showing - dont have my glasses right now. SteveShannon 1 Quote
SteveShannon Posted April 23, 2024 Report Posted April 23, 2024 Just now, WRXR255 said: My display has no "." so its showing 28300 kHz... I screwed up the MHz / KHz its showing - dont have my glasses right now. So it really changes 5 kHz on fast and 1khz on slow, right? That probably takes forever to sweep from one end to another. Quote
WRXR255 Posted April 23, 2024 Report Posted April 23, 2024 1 minute ago, Sshannon said: So it really changes 5 kHz on fast and 1khz on slow, right? That probably takes forever to sweep from one end to another. Yeah, but I did find the manual online so I hope its settable. Its a funky radio for sure. Those tiny buttons, Arr! SteveShannon 1 Quote
SteveShannon Posted April 23, 2024 Report Posted April 23, 2024 3 minutes ago, WRXR255 said: Yeah, but I did find the manual online so I hope its settable. Its a funky radio for sure. Those tiny buttons, Arr! Hopefully that STEP button will help. WRXR255 1 Quote
Gnarlykaw Posted April 23, 2024 Author Report Posted April 23, 2024 This gives me a better understanding now. I'm not doing much in VFO as of yet, so this wont have any bearing then.... BUT ill leave it at 12.5 for now. Thanks all. SteveShannon 1 Quote
