Uniden Bearcat scanner for GMRS.
Long story short...
I'm trying to set up my elderly fathers base. He has limited income.
Bearcat Uniden scanner BC355 with RG58 coax, worked well with a cheap CB Antenna for monitoring police activity. Changed to an Ebay cheap GMRS antenna.(looking for a better one currently.) Radio is frequency programmed for GMRS. He is not receiving my 50 watt tx, no better than my HT distance. Obviously need a better antenna. What all do I need? Is RG58 coax OK to use?
What antenna is needed?
Is coax OK to use for receiving and possibly tx in the future?
Future plans a 50watt base.
Thanks for advice.
1 answer to this question
4 hours ago, WSCA810 said:
Long story short...
Bearcat Uniden scanner BC355 with RF58 coax, worked well with a cheap CB Antenna for monitoring police activity. Changed to an Ebay cheap GMRS antenna.(looking for a better one currently.) Radio is frequency programmed for GMRS. He is not receiving my 50 watt tx, no better than my HT distance. Obviously need a better antenna. What all do I need? Is RF58 coax OK to use?
Thanks for advice.
I assume you mean RG58.
It certainly might be the antenna, but I would consider the coax first.  RG58 attenuates nearly 12 db at 400 MHz.  Every 3 db is half of the signal or power, so 3 db loss is 1/2, 6 db is 3/4, 9 db is 7/8, and 12 db is 15/16 of the power lost.
Coax is fine, as long as it’s a type that’s compatible with the frequency used.
