GMRS and 800mhz scanner antenna
WSCU736
6 answers to this question
7 minutes ago, tweiss3 said:
you should make sure you have plenty of separation and/or insert an RF limiter between the antenna and scanner to make sure you don't fry the scanner front end.
I was going to mention the same thing.  Not sure about older type scanners, but if it is a newer, SDR-type scanner like my SDS200, they are VERY sensitive and too much power, too close to the antenna can bork it.
Link to comment
Share on other sites
Well thank you. I was thinking it may do that. But I wanted to make sure.
Link to comment
As usual there are always a few different solutions.   I use a single antenna with a scanner(sdr) and gmrs (wouxun kg1000).  I use a antenna switch between the two.  The antenna I use is a compactenna (there are probably less expensive solutions), however this seems to work quite well.   The swr numbers for gmrs are in the 1.2-1.4 range, the antenna is advertised as a SCAN-III antenna.  The scan ranges given are 100mhz to ~1ghz.  I went with a single antenna for a few reasons and so far it has been a very good solution.   Whatever you choose just make sure and use good lmr400 coax.  Low quality coax can really attenuate any signal to or from the antenna.  Best of luck
Link to comment
